Now how do I stop this engine? - MVAgusta.net
post #1 of 6 (permalink) Old 11-11-2017, 03:42 AM Thread Starter
Mollbhan's Avatar
Hi all, the ignition switch on my 1971 150GTL has three positions, turned to the left engine runs with the headlight on, in the middle position engine runs no lights, turned to the right engine runs sidelight on, even removing the key engine still runs.
Question is should there be a killswitch fitted or is the ignition switch faulty? At present other than stalling the engine there is no way to stop it.
Mollbhan is offline
post #2 of 6 (permalink) Old 11-17-2017, 01:25 PM
Hey!
could you attach a photo of the switch type? However it sounds like mine RS150. Left headlight, middle no light, right no idea but engine runs.
The thing is when you remove the key from the switch, it should commute the conections to grouond. In other words, when the key is not there, the current generated by the generator is shortcutted to the frame (ground); when the key is in, the connection plate is moved, and the current generated feeds the battery and the lights.
Hope this helps
Dong
DongXu is offline
post #3 of 6 (permalink) Old 11-18-2017, 03:38 PM Thread Starter
Mollbhan's Avatar
Thanks for the helpful reply Dong it seems obvious there is a problem with the switch as taking the key out does not break the circuit, I will investigate further, all the best, Colin.
Mollbhan is offline
post #4 of 6 (permalink) Old 11-20-2017, 08:09 AM
Hey again,
maybe you have done it already, but check the contacts from the switch, give them a nice sand-paper treatment to the contacts. The rust may be the cause. Keep us tuned
DongXu is offline
post #5 of 6 (permalink) Old 11-21-2017, 02:52 PM
squibby's Avatar
As DongXu was explaining, taking out the key does not 'break the circuit' it evidently grounds out the ignition. Even many modern kill switches on basic motorcycle do this. So just worth understanding so you don't head in the wrong direction. (I know nothing about this bike by the way, I just know from experience that kill switch/ some ignition switches on old and even many modern basic motorcycles often ground out the ignition to kill the engine). all the best
squibby is offline
post #6 of 6 (permalink) Old 11-22-2017, 05:42 PM
DiscoStu's Avatar
I have the same issue with my 1957 175 CSTL. I have to stop it by blocking the air filter with my hand. I thought that was the only way as my Gilera of similar vintage is stopped by the decompression lever. Looking at the wiring diagram for my bike it looks as though removing the key should ground the generator and disconnect the battery. I will also investigate my ignition contacts/wiring arrangement. Will also prevent someone from starting it without the key!
DiscoStu is offline
