Few queries 150GTL - MVAgusta.net
post #1 of 3 (permalink) Old 10-31-2017, 06:03 PM Thread Starter
Mollbhan's Avatar
Few queries 150GTL
Hi all, new boy here and new bike, my first MV, it is a 1971 150GTL in stunning condition however I find it difficult to start as I have to literally bounce on the kickstart to get it over compression, I may add I weigh 11 stone and have always had bikes big and small and never struggled to turn them over. It seems strange as it is only 150cc, is this usually an issue? Another query is the carb, it is a 22mm dell orto which seems unusually large for a small 4 stroke, is this the standard carb? Finally does the 150 share the same cycle parts as the 125 and 175 of the same era, are they just a bored out 125? I would love to hear from other 150 owners.
Mollbhan is offline
post #2 of 3 (permalink) Old 10-31-2017, 09:03 PM
Old tip for starting high compression singles......push the kick starter through until you come up on compression, then slowly push it just past compression. Now give it a good kick.
Some big singles from Japan had a sight glass and an indicator on the cam shaft so you could find TDC compression...and a de-compressor lever you pulled to allow you to move the engine just past that point (Yamaha SR500 as example). Otherwise you could never start it !!!!
Can't speak to your other questions, but I know some one here will.
post #3 of 3 (permalink) Old 11-03-2017, 12:12 AM
Hi
I am not really familiar with 150GTL from 1971. Are you perhaps talking about the 150RSS which looks identical to the 125 GTLS or the 150GT? In that series, there is 125GT, 125 GTLS, 150GT and 150RSS Assuming, that we are talking about the same model, I had difficultly starting mine (125 GTLS) and found the gap in my points was too closed - it should .35 -.45mm on all those models (I've not heard of a 175 in that range) Before you going anything, please post a pic so that we can identify the bike correctly and are sure what we are talking about.
Rob
MVA - Maserati Vespa
Agusta
MVista is offline
