MV 175 CS Valve Rocker - MVAgusta.net
post #1 of 1 (permalink) Old 10-12-2017, 03:25 PM Thread Starter
I'm looking for valve rocker to finish the rebuild of the engine of my 175 cs. It was a long way. I had to change all bearings of the gear box, some of the gears and the bearing of the bottom end, fixed a new clutch an a new chain for the cam. I has to rebuilt the crank too. I fix a new piston from the css type with the highest compression and at last I need a new valve rocker. Who can help me?
Regards
Alexander
Johannestiger is offline
