Fly-Wheel Removal on a 150 - MVAgusta.net
post #1 of 4 (permalink) Old 10-11-2017, 02:30 PM Thread Starter
In an attempt to make some sense of the electrics - everything, coil, wiring, etc all missing as acquired - I decided to try and remove the fly-wheel. But how to hold it still when undoing the crank shaft nut? This is the answer I came up with, a bit crude but may help someone with the same problem. Nothing more that a length of 1" x 1/4" bar with two 1/2" "pins" fixed with their centre corresponding with slots in fly-wheel. The bar was drilled and taped and lock nuts fitted on top. In use the bar was laid across the nut with the pins in the slots, holding the bar in one hand and the spanner in the other the crank nut came off without damage. The fly-wheel has an internal thread for the puller, I was going to make this as well, but in the end idleness prevailed and I just bought one. Nothing got stressed (including me), photo shows the set-up
Jacks the Lad is offline
post #2 of 4 (permalink) Old 10-11-2017, 03:32 PM
Well done.... It's a good man who makes his own tools !!
Wouldn't have tried the puller, though. Too much work, and needs to be hardened. It's a smart man who buys the tool that are hard to make himself!!!
post #3 of 4 (permalink) Old 10-11-2017, 05:02 PM
Hey John, good to hear you decided to strip her off Good start from the flywheel, how does it look underneath?
This is how I took the wheel off:
to keep it from spining, I used pneumatic wrench and after a fast "Bzzz" noise, the locking nut came off. Then I used the flywheel extractor ( if you need this puller, I can look for the link , but it is quite a common measurement, easy to find)
You have to be absolute carefull removing the flywheel ! This is very important, and I hope the tool you made did not scratch any part of the coils and magneto. NEVER use a screwdriver to keep the wheel from spinning.
Test what´s underneath the wheel. Most of these bike after this long period, the points stop working properly. Disconnect them, check them, and pray they work.
Check also the rest in there, and make sure the electronics work, and also the clutch pusher is not stucked. If you need more info , I can add a link or two.
After assembling them back on, check if by spinning the flywheel manually or by kickstarter, you are getting AC voltage from the red and black wires that come from the generator. It should read around 2v-4v at this speed. ( With the enging working, it should supply 6,7v or so )
PD. I got your mail, looks nice the bike, but I bet there are many missing parts in thos boxes.
Regards,
Dong
DongXu is offline
post #4 of 4 (permalink) Old 10-11-2017, 05:03 PM
Motore MV Agusta 150 4tempi
this should help
DongXu is offline
