How to Refill front Fork Oil in RS150 - MVAgusta.net
post #1 of 1 (permalink) Old 10-29-2016, 08:50 AM Thread Starter
Help - does anyone know the correct procedure for re-filling the fork oil on an older MV Agusta - in my case a 1959 RS150. I removed the oil exit allen key screw at the bottom of each fork leg to empty the oil. I had earlier removed the large allen key screw at the top of the fork (near the triple clamp) and used a syringe to then replace about 130ml of Castrol Fork Oil 10 sae, very slowly. However - I must have done something wrong, because there is no proper damping effect now. Has anyone done this on an older MV Agusta motorcycle of the 60's? Regards, Mike, in Australia
gem550 is offline
