sump plate - MVAgusta.net
post #1 of 2 (permalink) Old 09-19-2016, 07:26 AM Thread Starter
ddmv's Avatar
sump plate
Hi all.
Putting a post on different sites.
But if anyone knows were i can source a sump plate for my CSGT 175 will be great.
Otherwise looking at getting one made.
thanks
ddmv is offline
post #2 of 2 (permalink) Old 09-21-2016, 09:47 AM
Is this what you're looking for?
I'm not trying to tease you- mine isn't for sale, but I need another one and plan to get a local shop to make one- I could get another made, or send you the drawing your machinist could use to make it.
It's a little odd- not sure why the inside center cavity is needed, or why the mounting bolt holes are recessed on both sides- there appears to be lots of clearance between the plate and the oil pump, but the recess won't be a problem.
I don't like the o-ring groove being broken at 2 of the mounting holes either- the ring could expand into that counterbore and not seal- I may not counterbore the bolt holes on the inside surface, but I need to study my basket case engine some more- maybe there were o-rings around the bolts on the inside?
I have a CSGT also.
Rick
chip is offline
