In case anyone is interested in the almost finished project... - MVAgusta.net
post #1 of 20 (permalink) Old 07-09-2015, 07:18 AM Thread Starter
test drove it last night, mostly all good, chassis has no bad habits so I can move on to paint. I still have one issue, it pukes oil out the breather when riding, nothing at all when standing still. I am not sure about the wierd rotary breather valve on these things, maybe I dont have that timed right. Maybe a baffle missing somewhere. Put the motor together without much to go on. I have a vid clip of the test drive if anyone wants. I am not happy with the seat cover, daughter has promised to help with a new one. Ignore the fork leg dust covers, used from the parts bin for the test drive.
js vermont is offline
post #2 of 20 (permalink) Old 07-09-2015, 07:49 AM
TheX's Avatar
Hmmm,
TheX is offline
post #3 of 20 (permalink) Old 07-09-2015, 08:50 AM
Looks really nice!!! Hope you get the breather sorted. May want to do a leak down test to be sure it's not piston ring sealing (or loss thereof) pressurizing the crankcase and blowing the oil out.....that is, if it ain't the breather valve timing....
Good luck. Looking forward to finished photos.
post #4 of 20 (permalink) Old 07-09-2015, 10:09 AM Thread Starter
hey thanks, just about positive its not blow by. only happens you lean or tip the bike, combustion is real clean.
post #5 of 20 (permalink) Old 07-09-2015, 10:40 AM
I don't know anything about your 'rotary breather valve', but most of these old bikes used a 'draft tube' crankcase ventilation system- air moving past the end of the tube would create a low pressure area so the higher pressure in the crankcase would force vapors out- that would explain why it isn't hosing your rear fender down when it's standing still. But, there shouldn't be that much discharge.
Rick
chip is offline
post #6 of 20 (permalink) Old 07-09-2015, 10:49 AM Thread Starter
I have been in many motors and I have not seen this sort of breather valve either, but behind the points , on the cam, is a disc with a port in it. Timed to the crankshaft. I am guessing I have it timed wrong, but will do a takedown while I am painting the bike. If anyone has experience wtih this setup, would love the input. Did the 350 keep this same arrangement?
post #7 of 20 (permalink) Old 07-09-2015, 10:59 AM
You could rig up a hose and catch can from your oil filler cap and see what happens when you just bypass the rotary valve- maybe the valve intake has fallen into liquid oil.
And, the way your tank and seat wrap around the frame tubes looks good- the Disco/Imola look is a nice fit to the rest of the bike.
Rick
chip is offline
post #8 of 20 (permalink) Old 07-09-2015, 11:51 AM
I love your project. Would like to see better photos of the swing arm, it looks really cool. And good luck with the oiling issue. I fought a similar issue on a Triumph 650 for a couple years. A dry sump motor so completely different cause, we think it was a lack of suction in the scavenge side of the oil pump. Surfacing the back of the oil pump seemed to finally do the trick. Are you sure your 350 is not over filled? On Ducati bevel twins, we always run the oil level at the lower of the 2 grooves on the dipstick, which helps keep the oil in.
1954 MV 175 CSS Super Sport
1957 MV 175 CS Modello Sport
1967 Motobi 125 Sport
1974 Ducati 750 GT
Left Coast USA
hulagun is offline
post #9 of 20 (permalink) Old 07-09-2015, 12:32 PM Thread Starter
Thanks guys. The Disco/Imola mashup is exactly what I was thinking when making this, so glad you picked up on it. The swingarm is one I made out of ,I think, a moto-morini item, narrowed and braced, axle slots welded up. The pivot was machined by a gentlemen out in Colorado that originally had the motor. He was going to use it on the project. Its as far as he got on it. its a nice piece of work, so I used it. I can take a close up if you would like.
1968 MV Agusta 250b
1970 BSA 441
1974 Laverda 750SF
1977 Ducati 900SD Darmah
1978 Ducati 900SS
1979 Moto Guzzi CX100 LeMans
post #10 of 20 (permalink) Old 08-18-2015, 08:02 AM Thread Starter
finally got around to uploading a video of the first ride. please forgive the stupidity of the no helmet. just a drive around the local industrial park.
http://s24.photobucket.com/user/john...tml?sort=3&o=0
1968 MV Agusta 250b
1970 BSA 441
1974 Laverda 750SF
1978 Ducati 900SS
