175 SS engine? Looks at the camshaft - MVAgusta.net
post #1 of 12 (permalink) Old 03-14-2015, 10:18 AM Thread Starter
Hi, I have bought this engine 409884 s. The rocker arms are narrower as with my 47 ........ s motor. Besides these you apparently possible to the camshaft, a fine adjustment of the control times. The cover for the breaker is fixed with screws 3. What do you thinkI Is it SS technology? Hope someone writes me. Regards Torsten (Jarno)
Jarnoparoni is offline
post #2 of 12 (permalink) Old 03-15-2015, 09:16 AM
GTW36's Avatar
That's a true CSS engine with the specific "vernier" system to set accurately the camshaft timing gear .
The CS engine has a simple key to fit the gear.
GTW36 is offline
post #3 of 12 (permalink) Old 03-15-2015, 05:12 PM
I think it looks like an cs. I can not see any diffrence to my cs engine. Someone told, the camshaft itself of the css engine ist built in two parts and fixed together in a way that it is possibel to adjust each part for itself. This connection between the sprocket and the cam with this special part which has so many holes is the same as in every 175 ohc engine.
Regards
Alexander
Johannestiger is offline
post #4 of 12 (permalink) Old 03-15-2015, 07:47 PM
My understanding is the same as Dominique's but having said that I am not saying Alexander is incorrect - having received mine only recently, I find the head makes a different noise to all other MV engines I have experience with and for want of a better description sounds like a gravel cruncher. Looking at the design I can see why it sounds as it does.
When I get a 'new' bike I like to set it up, double check all clearances etc - so when I pop the cover off mine I will photograph it for comparison to these photos.
Rob
MVA - Maserati Vespa
Agusta
MVista is offline
post #5 of 12 (permalink) Old 03-15-2015, 10:01 PM
This is the camshaft with the double vernier- one modifies the timing between the crankshaft and the camshaft and the other modifies the phasing of the cam lobes.
Rick
chip is offline
post #6 of 12 (permalink) Old 03-16-2015, 01:54 AM
The cam an chips foto is that what I have meant it belongs to a CSS. Do the CSS have a 5 speed gearbox? Then it's easy to identyfie.
Regards
Alexander
post #7 of 12 (permalink) Old 03-16-2015, 02:24 AM
GTW36's Avatar
Hi Alexander,
you're true, the double vernier is CSS
GTW36 is offline
post #8 of 12 (permalink) Old 03-16-2015, 06:39 AM
akesvantesson's Avatar
it looks like ordianry cst rockers , and also the (castaletto)Carrier
the css cam is adjusteble and lift 8.8 and the solid cs will lift 7,6 mm
the cs modello sport and css are solid rockers ,, no oilfeeds in the castaletto ,
kind regards Åke
akesvantesson is offline
post #9 of 12 (permalink) Old 03-16-2015, 06:43 AM
cst / cs s castaletto difference
see the difference
post #10 of 12 (permalink) Old 03-16-2015, 02:45 PM
Originally Posted by akesvantesson View Post
see the difference
Yes, Ake, this one on your picture looks just the same as the castaletto from my CS engine. Indeed, the other one from Thorsten's engine looks like one from a CSTL. Seems that someone has built an engine together with parts from various models. But the cam seems to be one from an CS, because of the connection to transmission of the speedometer cable.
Regards
Alexander
