910 Guess the stock dyno - MVAgusta.net
post #1 of 19 (permalink) Old 04-06-2006, 06:55 AM Thread Starter
CB910's Avatar
I just got the results for the dyno runs for my new 910. I had a base run done on the stock bike and then after the MV-SP headers and PCIII w/a custom map.
Guess what the stock 910 dyno'd @ ?
Come on, don't be shy.
CB910 is offline
post #2 of 19 (permalink) Old 04-06-2006, 06:56 AM
Living the Dream
Greeneggs&ham's Avatar
135 before, and 147 after
Get busy livin, or get busy dyin
Motorcycle Art!
You live more in 5 minutes on a bike like this, going
flat out, than most people live in a lifetime.
Greeneggs&ham is offline
post #3 of 19 (permalink) Old 04-06-2006, 07:23 AM
Rear wheel
Before :117
After : 125
Nidan is offline
post #4 of 19 (permalink) Old 04-06-2006, 07:26 AM
airfuel's Avatar
Depend on the dyno but a DynoJet dyno would most likely see about 120hp stock and hopefully 128hp with the mods. (rear wheel)
This is using the SAE correction factor and about 12% driveline loss.
4th gear pulls also,(industry norm) 5th gear will give inflated numbers.
This is real world wheel horsepower, not some "happy" dyno numbers.
STD, uncorrected or DIN numbers will be higher.
What do I win?
John T
airfuel is offline
post #5 of 19 (permalink) Old 04-06-2006, 07:39 AM
Question
What do I win?
John T
John, is 12% driveline loss a nominal figure for most bikes?
Keep one wheel down!
No MV's in the garage anymore
john is offline
post #6 of 19 (permalink) Old 04-06-2006, 08:57 AM
airfuel's Avatar
Chain drive bikes average about 11-14 percent. Many conditions contribute and it is hard to put an exact figure on it.
Chain condition and tightness, tire pressure and size/weight, rear brake drag, bearing condition and even the oil used will change the numbers.
Shaft drives are usually in the 16-20% driveline loss.
John T
airfuel is offline
post #7 of 19 (permalink) Old 04-06-2006, 08:06 PM
airfuel's Avatar
Well? What are the numbers? Post a graph!
airfuel is offline
post #8 of 19 (permalink) Old 04-06-2006, 08:25 PM Thread Starter
CB910's Avatar
No prizes.... 'cause Cynthia didn't guess. She would have won a bike date.
Nidan was closest. Stock= 113. Yes, that surprised me too.
After= 125.
CB910 is offline
post #9 of 19 (permalink) Old 04-06-2006, 10:18 PM
rob
I just put my f41000 on a dynojet dyno on tues night with rg3 and mid pipe and chip. It put out 130hp running no correction just straight rear wheel hp.
A ZX10r was running 127hp in comparison
rob is offline
post #10 of 19 (permalink) Old 04-07-2006, 02:02 AM
After= 125.
I won !
I won !
where's my prize ???????
No prize.......
Ok - A question then ....
Do rizoma handlebar grips fit the brutale ?????
Nidan is offline
