2012 1090RR vs 2014 1090RR - MVAgusta.net
post #1 of 11 (permalink) Old 03-03-2014, 06:50 PM Thread Starter
What are the differences between these two models? Did the bike get updated at all?
Octan090 is offline
post #2 of 11 (permalink) Old 03-03-2014, 09:28 PM
xs2
older frame was tig welded,newer mig, tig is cleaner my 2cents
xs2 is offline
post #3 of 11 (permalink) Old 03-03-2014, 11:23 PM Thread Starter
Is that it? Engine, electronics, suspension, software.. nothing?
There are some good deals on low mileage 2012's
Octan090 is offline
post #4 of 11 (permalink) Old 03-03-2014, 11:44 PM
revhead1957's Avatar
Worth checking, but I thought 2014 gets the Eldor ecu for a start?
At some point in the history of the 1090RR it picked up some of the engine parts from the F4. There was an increase of hp at the expense of midrange torque. The final drive ratio was changed to compensate for the loss of low end grunt.
Trim details changed, such as the cover over the exhaust flapper valve and radiator side covers.
The overall spec of the bikes seems to be different too, according to which country is being supplied. E.g. ABS mandatory for Europe?
revhead1957 is offline
post #5 of 11 (permalink) Old 03-04-2014, 03:30 AM
cherche's Avatar
The 14 model year is exactly the same as in 13 - so no changes at all. The old Magneti Marelli 5SM still is alive .
The 13 model year had a grey engine and new grey wheels, a different cockpit fairing with LED position lights. In 13 they introduced an optional ABS, in 14 standard.
AFAIK no technical differences between the 12 and 13 model year.
With some minor mods and mapped mine has 180 hp and app. 115 Nm at the crank.
Cannot wait for the riding season .
Jochen
2018 Brutale 800RR
cherche is offline
post #6 of 11 (permalink) Old 03-04-2014, 05:17 AM
pikfee's Avatar
the 2012 model has the lighter forged wheels in them
same as now used on the corsa
also tig HAND welded frame much cleaner and somewhat lighter
no engine changes..
the 2012 is the last off the REAL RR`s
cheers
Peter
THERE'S NO SUCH THING AS "TEAMWORK"
pikfee is offline
post #7 of 11 (permalink) Old 03-04-2014, 08:02 AM
Mark V.'s Avatar
Prior to 2013, RR model had hand made chromoly tig welded frame,more horsepower due to 49mm throttle bodies with high lift cams and shorter inlet manifolds, this increases rev limit by 600 rpm,marchesini wheels, better front brakes,steering damper,better rear shock and a slipper clutch. 2013RR went back mig welded steel frame.Slight body panel changes between models, muffler tips different and wheels
Mark V. is offline
post #8 of 11 (permalink) Old 03-04-2014, 09:41 AM Thread Starter
Man, I was trying to hold out for a Dragster, but this thread is making me want to buy a couple year old 1090RR
Octan090 is offline
post #9 of 11 (permalink) Old 03-04-2014, 11:00 AM
cherche's Avatar
Not really. In all dyno charts I found the rev limiter is set to 11600 rpm as on the R. Mine also only did 11600 rpm.
Check this out:
http://www.mvagusta.net/forum/showthread.php?t=80001
2018 Brutale 800RR
cherche is offline
post #10 of 11 (permalink) Old 03-04-2014, 07:55 PM
Mark V.'s Avatar
Smile
Check this out:
Whoops was quoting from net, 250 on my brute is well fast enough! Awesome feeling when you hit a ripple in the road at top speed and she gently lofts front in controlled wheelie, fantastic handling at high speed for a naked
Mark V. is offline
