Stuck gearbox on Brutale 1090RR? - MVAgusta.net
post #1 of 16 (permalink) Old 12-31-2013, 12:17 PM Thread Starter
pierre.poilane's Avatar
7500 miles service done a couple weeks ago. This morning I take the bike out and head to the gas station for a fill up a couple blocks away from home. After filling up, I start the bike and it stalls as I leave. I restart it fine then realize that I cannot shift higher than 2nd gear. Downshifted and upshifted a number of times and was able to get up to 3rd gear. Shifting within the three gears feels either loose or hard.
No funny noises or dripping fluids. Any clue what the issue could be? Did the stall unhinge something in the gearbox? Could this be just the shifter misbehaving?
Thanks in advance for sharing any insights.
pierre.poilane is offline
post #2 of 16 (permalink) Old 12-31-2013, 12:18 PM
Broken shift return spring. It is a recall item. Check with your dealer.
post #3 of 16 (permalink) Old 12-31-2013, 12:51 PM Thread Starter
Thanks for the info. I was planning on taking it to the dealer but found it's always a good idea to eliminate a lot of the guesswork on their part by tapping into the amazing wealth of knowledge and experience of this board. Didn't take long...
post #4 of 16 (permalink) Old 01-06-2014, 07:56 PM
on a side note , anyone have issues where the bike ocasionally pops out of 1st\2nd into netural
it is usually just after a gear change , i think the box is still wearing in its at about 5000km , but its slightly crappy
hotsuma is offline
post #5 of 16 (permalink) Old 01-07-2014, 05:33 AM
That shouldn't happen.
post #6 of 16 (permalink) Old 01-08-2014, 12:39 AM
hotsuma;
shift detent spring is weak......and or the shift return spring is weak
back to the dealer
sorry
post #7 of 16 (permalink) Old 01-09-2014, 12:44 AM
Is weak shift detent spring or return spring a common problem.
RUDY
_______
Mv Agusta '13 1090
TaskforceRudy is offline
post #8 of 16 (permalink) Old 01-10-2014, 01:25 PM
The reason I asked the question about the shift springs is because I have a '13 1090 with 200 miles on it and it's going into "neutral" when shifting to 5th gear. It's very weird. It hasn't fallen out of gear. This happens occasional when shifting to 5th gear. When I'm up shifting and I release the clutch it feels like I'm neutral.... BUT sometimes if I roll off the throttle and then roll it back on it goes into gear(with out manipulating the clutch). Then other times when shifting to 5th; to get it into gear I have to just engage and release the clutch and it pops into gear. The gear indicator on the display is indicating 5th gear. Bike is brand new so I'm not super concerned yet. Any thoughts? Is this a spring problem or a new bike problem.
RUDY
_______
Mv Agusta '13 1090
post #9 of 16 (permalink) Old 01-10-2014, 02:58 PM
It could be a technique problem.
post #10 of 16 (permalink) Old 01-10-2014, 03:23 PM
revhead1957's Avatar
New bike issue. I found a lever adjustment helped.
revhead1957 is offline
