Clear Alternative rear light (help!) - MVAgusta.net
post #1 of 7 (permalink) Old 02-19-2007, 05:57 PM Thread Starter
clandestinejinx's Avatar
Where in gods name am I supposed to mount or install this factory relay? I found the instructions to be shoddy and found no relay bank under the tank as stated in the weird sticker instruction. Also had to use a volt meter to find out wich wire to connect the yellows to and am heading to Radio Shack to build some connectors as the ones provided are the crimp type that put gaps in the insulation on the wires.
Anyway, where the hell does the relay go? How do I put it in. Called Clear Alternatives and got the fax all day.
clandestinejinx is offline
post #2 of 7 (permalink) Old 02-19-2007, 05:59 PM
airfuel's Avatar
You don't use the relay on the Brute. Just wire it up and it will work fine.
John T
Certified Power Commander Tech.
Authorized Tuning Center/Dealer
airfuel is offline
post #3 of 7 (permalink) Old 02-20-2007, 09:34 AM Thread Starter
I am not sure about that but I will try to contact Clear Alternative and see.
post #4 of 7 (permalink) Old 02-20-2007, 09:45 AM
Always trust in John. All you need to do is wire it up. You do not need the relay. I have the clear alternatives rear light. That's all I did.
MVITALIAN is offline
post #5 of 7 (permalink) Old 02-20-2007, 10:43 AM
Motovation has written their own install sheet. Maybe this is better. Click on Install link on page:
Brutale CA Tailight Install Isntructions
kilat is offline
post #6 of 7 (permalink) Old 02-20-2007, 11:44 AM
mike21's Avatar
Mine is looking like this after installation...the resistor is for reducing the blinking tempo..i left mine blinking faster.that is i didnt use the resistor.Mine is from eMoto.uk and there was not any relay???only the resistor.Just follow the instruction it should be quite easy..
Starfighter Titanium R
Ducati 998S
mike21 is offline
post #7 of 7 (permalink) Old 02-20-2007, 02:03 PM Thread Starter
Instructions were crappy but Arifuel was right about the flasher module. Cant use it. Finally got ahold of them.
