989 Brutale - MVAgusta.net
post #1 of 11 (permalink) Old 10-01-2013, 03:31 PM Thread Starter
phillo45's Avatar
989 Brutale
Hi lads,just joined the site.Im doing a deal with a garage on an 2010 Brutale 989,are there anything i should look for.It has a Microtec ECU and Arrow Thunder can.There is 7100 miles on it,when are the valve clearances done and is there a problem with the rear wheel hub.I would appreciate your comments and advice,Cheers.Phillo
phillo45 is offline
post #2 of 11 (permalink) Old 10-01-2013, 04:12 PM
revhead1957's Avatar
Welcome aboard. If there is a problem with the rear hub you will need to factor in a substantial price reduction. Do a search here and you will find likely causes for this to happen.
revhead1957 is offline
post #3 of 11 (permalink) Old 10-02-2013, 12:31 AM
cus
cus's Avatar
Valve clearance check is usually at 12,000ks (about 7200miles I believe)
cus is offline
post #4 of 11 (permalink) Old 10-02-2013, 01:42 PM
steve1968's Avatar
Just had my valve clearance service on my 1090RR and its a £400 + job so factor that in .
steve1968 is offline
post #5 of 11 (permalink) Old 10-02-2013, 03:10 PM Thread Starter
phillo45's Avatar
Thanks,is the rear wheel hub issue a problem on all MVs from the older ones to up to date models.Cheers
phillo45 is offline
post #6 of 11 (permalink) Old 10-02-2013, 05:40 PM
2010 and later got an updated design hub which reduced the issue. Setting the chain tension too tight, over tensioning of the hub pinch bolts and lack of service are the major causes of failure.
I strongly recommend doing a search on the forum.
post #7 of 11 (permalink) Old 10-03-2013, 04:48 PM Thread Starter
phillo45's Avatar
Cheers thank you.Does this happen on all MVs or is it just down to people being neglectful.I presume the cost is a lot if it does happen yeah.Any idea how it is looked after as in servicing the hub regarding greasing it
phillo45 is offline
post #8 of 11 (permalink) Old 10-04-2013, 02:39 AM
Wink hubs?
phillo45;
do a search as revhead1957 said;
an "updated Factory hub" uses a single row ball bearing where the original double row failed......truly engineering lunacy
the balls are 3.5mm.....roller skates have bigger bearings
check out the Mitch Hub......less money than the "updated Factory hub"
and bullet proof
post #9 of 11 (permalink) Old 10-04-2013, 05:36 AM
Pretty sure the 989 has the "new" hub, follow maint procedure.
post #10 of 11 (permalink) Old 10-14-2013, 03:21 PM Thread Starter
phillo45's Avatar
Well lads i got my first MV today.Its a 989r in silver and its stunning,i took the boat from Rosslare to Fishguard and met the dealer there.Now its time for more carbon,any of ye get carbon from Ducati Corse in the UK.I was going to purchase but wonder if its any good.Cheers Lads,Phillo.I will post some pics soon
phillo45 is offline
