910 or 920 ? - MVAgusta.net
post #1 of 12 (permalink) Old 06-19-2013, 06:31 AM Thread Starter
sms
sms's Avatar
910 or 920 ?
hi alll, i wana decat my 989r, do i need a 910 or 920 decat to cut and shut ?
sms
sms is offline
post #2 of 12 (permalink) Old 06-19-2013, 11:42 PM
Do the headers go straight into the cat or is there a join there ?
rsawkins is offline
post #3 of 12 (permalink) Old 06-20-2013, 12:06 AM
Thumbs down welded?
Rich;
my '08 pipes were welded to the cat......i cut it all apart, no deal, the collectors curve into the cat.....where they need to be straight
got head pipes and a catless collector from Carl, then an Arrow Shorty
post #4 of 12 (permalink) Old 06-21-2013, 10:40 AM Thread Starter
sms
sms's Avatar
Rich;
yeah welded, so just cut and shut?
thanks again guys, will do it this weekend!
SMS
sms is offline
post #5 of 12 (permalink) Old 06-24-2013, 09:50 PM
Wink ?
SMS
SMS;
no, not cut and shut what ever that means?
never seen a 920 or 989
the '08 910R head pipes are welded into the Cat, its a big box....
i cut the head pipes out of the box.....they will be major work to connect
you need to remove the curved ends
you need to machine the correct ends and weld them to the ends of the head pipes
then you need a Catless mid pipe to fit your modded headpipes, your stock Shotguns will fit the Catless midpipe
i'm fabricator, been welding for 57 years......
i bought early Brutale headpipes and a Catless collector.......it just bolts on......
you have to pick your battles
post #6 of 12 (permalink) Old 06-24-2013, 09:59 PM
Noel, "cut and shut", like when you have two wrecked cars, one front end crash, the other a rear. Cut the good bits of both and weld them together to make one "good" car
So in this case as you describe way too much work to cut the headers off the cat, weld bits on etc, so just buy headers off a 750 Brutale and use them with a suitable mid pipe ( arrows cat eliminator or gutted cat) and your silencer/tail pipe of choice.
rsawkins is offline
post #7 of 12 (permalink) Old 06-24-2013, 10:51 PM
eddypro's Avatar
look for my post on cutting ,with pictures?
eddypro is offline
post #8 of 12 (permalink) Old 06-24-2013, 11:00 PM
eddypro's Avatar
found it,hope it helps http://www.mvagusta.net/forum/showthread.php?t=40220
cheers eddy
eddypro is offline
post #9 of 12 (permalink) Old 06-25-2013, 12:10 AM
eddypro's Avatar
Wink
also ,you do need a spring as such.just unscrew the co screw and use a washer ,drill a 1/8 hole on the outer rim ,you can the rotate this to any angle,if you want the spring to be straighter than mine,your choice.
cheers eddy
eddypro is offline
post #10 of 12 (permalink) Old 06-25-2013, 12:17 AM
eddypro's Avatar
sms,you need to buy the mid pipe from http://www.motovationusa.com/mvstore...?idproduct=198
eddypro is offline
