06 910s Alternator issue... - MVAgusta.net
post #1 of 9 (permalink) Old 01-13-2012, 03:45 PM Thread Starter
Benno's Avatar
Hi,
I have a Brutale 910s.
A few days ago I had to recharge the battery because it hadn't been ridden for a while. When I put the battery back in, I cant remember if I accidently brushed the positive lead against the negative terminal or vice versa. Anyway, as a result the 30A battery recharge fuse blew. I replaced it and problem was fixed.
Two days ago I went on a trip away and the battery light came on after about 200 km.
I stopped a few km down the road and checked the battery recharge fuse. It had completely melted!
I replaced the existing 30A fuse and it started without a problem and idled as per normal. Anyway, as I revved the throttle to go the fuse blew again!
So, I replaced the fuse and managed to limp (keeping her under 4000 rpm, figuring the alternator ws playing up) to a nearby auto electrician.
He put a multimeter on the alternator and it was charging between 14.6 and 15.1. I think the correct charging amount is 13.8...
He seems to think the regulator/rectifier has had it.
My Dad lives close by so I managed to get to his place and that is where my Brutale remains until I can sort the problem out.
I have never had this problem before and I was wondering if anyone out there had any advice for me??
Benno is offline
post #2 of 9 (permalink) Old 01-13-2012, 05:24 PM
Prepare for an epic rant from theknurl, but if I'm not mistaken the rectifier is internal to the alternator and is not available separately.
The alternator is $1200 new from the dealer. (This is where Noel enters stage left.) Your best bet is to find a used alternator. Should be around $300.
post #3 of 9 (permalink) Old 01-13-2012, 06:17 PM Thread Starter
Benno's Avatar
Thanks CAG! I thought that might be the case!!
Any hints on where to get a used one???
Benno is offline
post #4 of 9 (permalink) Old 01-13-2012, 08:17 PM
Wink alternator?
contact;
http://www.ricksmotorsportelectrics.com/
there is an Ohm reading between the sliprings, if you're within the values, they can fix it otherwise CAG is where you go
post #5 of 9 (permalink) Old 01-14-2012, 01:37 AM Thread Starter
Benno's Avatar
Ok thanks boys. Will do some homework and let u know...
Benno is offline
post #6 of 9 (permalink) Old 01-14-2012, 01:56 AM
I'm on my third alternator . If it's the rectifier you can replace it with a honda one , only difficulty is its a 2 wire not 3 wire . All depends on whether you wish to remain standard. I also find it is pretty easy to remove. Just a bit daunting removing the engine first time, but it is fairly simple really. Couple of hours to replace alternator third time around
Kiwidoc is offline
post #7 of 9 (permalink) Old 01-19-2012, 05:27 PM Thread Starter
Benno's Avatar
Thanks for that.
I also realised that the battery recharge fuse in my Brutale is a 30A but in the manual it stipulates a 40A recharge fuse???
Would that be a reason it has blown a couple of times? ie not being able to put up with the charge from the alternator?
Benno is offline
post #8 of 9 (permalink) Old 01-19-2012, 09:47 PM
not sure with yours being an 06, but mine is a 40a fuse... i just replaced it after having hooked the battery up wrong :-(
ONAGER is offline
post #9 of 9 (permalink) Old 01-26-2012, 06:07 PM
cnegron's Avatar
I have a rectifier assembly I ordered when I researched this issue for someone else, it looks identical to the unit in the MV, I can send pics later. I believe I posted the part number for it, I will look and update the post.
cnegron is offline
