1090 mirror glass removal - MVAgusta.net
post #1 of 18 (permalink) Old 11-13-2011, 01:22 PM Thread Starter
steve1968's Avatar
Can this be done without breaking the glass ?
My R/H mirror body is a tiny bit loose on the stem and i presume there must be something to tighten behind the mirror glass .
steve
steve1968 is offline
post #2 of 18 (permalink) Old 11-13-2011, 07:57 PM
getec's Avatar
steve
Hi Steve, I have the same issue (loose mirror) and when the bike is travelling, there is a vibration in the RHS mirror...I am working on this..will let you know when I have an answer....
getec is offline
post #3 of 18 (permalink) Old 11-13-2011, 11:14 PM
racerxlilbro's Avatar
steve
On mine, mirror removal only required riding down the road. But, before that, I learned that you can rotate the mirror down and carefully pry the ball out of the socket with a screwdriver, or just pull down on the glass. Terrible design, really.
Go that way, really fast. If something gets in your way, turn.
racerxlilbro is offline
post #4 of 18 (permalink) Old 11-14-2011, 04:57 AM
getec's Avatar
Yes, terrible design...and thanks for the info !
Ride safe and take care.
_________________________
GETEC - Glenn
Vivere il sogno !
getec is offline
post #5 of 18 (permalink) Old 11-14-2011, 05:54 AM
racasey's Avatar
Easy fix
My 1090RR mirrors were a problem from the start, and this simple fix has worked well for almost two years.
I wet the ball with a few drops of water, sprinkled a few dozen grains of fine beach sand on the ball, the water retained the sand on the surface of the ball during the time it took to insert the ball back into the socket. The water soon evaporates, leaving the grit in place to provide added friction, eliminating the mirror drift, while allowing adjustment as required.
Sand, unlike things like chewing gum or adhesive tape is not affected by temperature, or aging, and the this quick fix has worked well.
Earlier attempts to tighten the simple steel coil spring surrounding the fingers of the socket were not as long lasting as the sand. The right side mirror has not needed adjusting in a few thousand miles.
Ciao,
Dick
racasey is offline
post #6 of 18 (permalink) Old 11-14-2011, 06:24 AM
getec's Avatar
Ciao,
Dick
Thank you ! Will try this out this weekend! Awesome!!
GETEC - Glenn
Vivere il sogno !
getec is offline
post #7 of 18 (permalink) Old 11-14-2011, 02:22 PM
Exclamation Here's How:
The way to remove the glass from the ball socket without prying is to gently press your finger into the upper outer edge of the glass...as if trying to adjust the mirror to a higher more outside view...be ready to catch the glass as it will pop out of the socket joint, without damage, when enough pressure is applied...and that isn't much!
post #8 of 18 (permalink) Old 11-14-2011, 02:28 PM
getec's Avatar
This is why this site rocks ! Tons of experience and knowledge in one location. Thank you silentservice!
GETEC - Glenn
Vivere il sogno !
getec is offline
post #9 of 18 (permalink) Old 10-22-2012, 01:46 PM Thread Starter
steve1968's Avatar
I still havent got round to sorting this out but having just cleaned my bike i have noticed its probably a little looser so better get it done .
I understand now how to remove the glass , can anyone tell me how the pastic pod is fixed to the stem ?
i.e will i be able to correct it once the glass is out ?
any advice welcome
Steve
post #10 of 18 (permalink) Old 10-22-2012, 02:15 PM
Wills's Avatar
If your bike is still under warranty, "accidentally" drop the glass and break it. MV will warranty replace both complete assemblies with a type that the glass does not move...or fall out! I put them on my bike and much improved. They are the Euro type mirrors.
Stop Global Whining
Wills is offline
