Another Rear brg takes a sh*^ - MVAgusta.net
post #1 of 25 (permalink) Old 09-21-2011, 11:49 PM Thread Starter
zmz rider's Avatar
Well after a few weeks of ownership I am joining the rear brg club. So, AAA paid off with a free tow home from work.
I was patting myself on the back for having bought a socket for the rear axle. Trouble is some of the posts about the left handed threads don't refer to the left or drive side of the machine. So I actually tightened the bastard nut. Broke two cheap breaker bars and lifted the rear of the bike off the ground with the jack handle for a cheater bar. Wife refused to sit on the bike to hold it down (probably wise on her part)
Well thanks to Noel for setting me straight on that one.
So tomorrow, I have to limp it up the street to Goodyear to see if they will lend the ole 1/2 impact.
Oh yeah, also sheared off a 6mm bolt that was keeping the wheel from turning. (through the rotor)
Tomorrow has to be a better day!
Glad it didn't go on the way home from Denver!
zmz rider is offline
post #2 of 25 (permalink) Old 09-21-2011, 11:55 PM
MVAgusta.net Sponsor
mitchy's Avatar
Shit,6mm bolt through the rotor
mitchy is offline
post #3 of 25 (permalink) Old 09-22-2011, 02:41 AM
The_castle's Avatar
Look, in the future, before you go doing pretty much anything to your bike have a look here and refer to the relevant section of the service manual.
http://my.agusta.us/
The_castle is offline
post #4 of 25 (permalink) Old 09-22-2011, 02:44 AM
jimboF4's Avatar
Welcome to the "hub club", re the 6mm bolt, where did that come adrift from? Not heard that one before.
A tip for undoing the reverse thread wheel nut, I hook the bike into second gear and get a helper to apply the rear brake hard. I use a 3/4 inch good quality breaker bar on the socket and a 5 foot length of scaffold tube, works for me.
Good luck with the repair and don't skimp on a cheapo replacement 3810 bearing.
jimboF4
jimboF4 is offline
post #5 of 25 (permalink) Old 09-22-2011, 06:34 AM
And why didn't you call me??? Noel can hook you up with bearings. What did you screw the 6mm bolt into to try and lock the wheel?
Anyway, once you have removed the over tightened nuts and properly torqued they will not be so tough the next time. Pay attention to the shop manual. Clean surfaces and light grease on first threads only if I recall (I have to refer to the manual every time as my aging brain can't retain even the most basic of specs).
post #6 of 25 (permalink) Old 09-22-2011, 09:07 AM Thread Starter
zmz rider's Avatar
Yeah, it was too late for East coasters and the 6 mm bolt trick I read about here. It secured the wheel from turning until it broke. Rotors are cheaper than trannies. Don't really want the trans taking abuse.
I plan to use never seize on assembly. The manual is taking a lonnnng time to open on my computer so I read some posts and went for it. Live and learn.
So hopefully the air tool will do the job. If not, a larger breaker bar.
And finally I have not even started on the reverse thread nut on the throttle side. That fun comes after I get the drive side loose.
Cheers and thanks for the advice.
post #7 of 25 (permalink) Old 09-22-2011, 10:13 AM Thread Starter
zmz rider's Avatar
Update,,, Goodyear and air tools made easy work of it. Had them loosen both nuts so tonight I can see what is really broke!
post #8 of 25 (permalink) Old 09-22-2011, 12:25 PM
Thumbs down don't!
DO NOT USE THE TRANSMISSION TO LOCK THE REAR WHEEL!
loop soft ties through the foot peg brackets then connect a tie down through the rear wheel to the soft ties. adjust the length of the tie down to make a 90 deg angle with the wheel spoke
if you have a rear hugger watch the routing of the tie down
transmission gears are case hardened, and you can crack them......
all you need is a broken tooth NOTHING, will put you down faster than a locked transmission
post #9 of 25 (permalink) Old 09-22-2011, 12:55 PM
daves1078rr's Avatar
As a new owner, what models are these bearing's going out on? Should I do Mitch's replacement just for peace of mind? I do lengthy road trips a few times a year.
daves1078rr is offline
post #10 of 25 (permalink) Old 09-22-2011, 07:31 PM
Thumbs up Mitch's hubs?
all models pre '10 have the same hub
for model years '10-'11, with MV's new design hub/axle, the record so far is something like 300mi before it died
Donsy races on a Mitch's hub and doesn't even bother checking it
i got 2, one for the F4 the other for the Brutale.....
i buy the 3810-2RS hub bearings 20 at a time, most people buy them from me 2 at a time so they have a spare, and very little down time
there has been a lot of serious interest since Brian got hurt in OZ....
i should be getting a new shipment in ~4 weeks
one is already gone, John sent a deposit to make sure he got one, even though this is pretty much the end of his riding season
