where to get a cam chain tensioner? - MVAgusta.net
post #1 of 13 (permalink) Old 06-19-2011, 11:07 AM Thread Starter
Hello all, I'm dealing with a 4-4.5k rpm rattle and I suspect it's coming from the cam chain. Since I've got the non updated tensioner, does anyone know where to get a new one before I start disassembling? cheers claudio.
Claudio is offline
post #2 of 13 (permalink) Old 06-19-2011, 06:14 PM
updated cam chain tensiner?
try ProItalia, a Forum sponsor.....
part # 8000A5206
post #3 of 13 (permalink) Old 06-19-2011, 08:05 PM Thread Starter
Smile
part # 8000A5206
Thanks much appreciated! Cheers
Claudio is offline
post #4 of 13 (permalink) Old 06-25-2011, 07:26 AM
mrdon003's Avatar
Depending on the year of bike I would check and make sure that your bike doesn't have a Service recall, my 07 F4r just broke its cam chain tensioner 7600 miles and found out there was one on mine, the part is paid for but had to pay for labor.
mrdon003 is offline
post #5 of 13 (permalink) Old 09-02-2011, 07:18 AM Thread Starter
There isn't a recall on this issue with the DOTARS (Australia) announcement. Hmm maybe a report could go in?
But nonetheless I've purchased the part and it isn't too hard to replace. However I forgot to notice which way up the tensioner goes back in...can anyone offer any advice? Thanks.
Claudio is offline
post #6 of 13 (permalink) Old 09-02-2011, 07:37 AM
gotojoe's Avatar
I should pm AdeCritten about this subject as he has recently fitted one.
Don't remove the old one until you are au-fait with the procedure or you could end up right in the mire..; )
joe
gotojoe is offline
post #7 of 13 (permalink) Old 09-02-2011, 08:00 AM
Rob_b's Avatar
Hi Claudio, Donsy posted the pdf on how to do it. I'm using it now to do mine
http://www.mvagusta.net/forum/showth...nsioner&page=3
Rob_b is offline
post #8 of 13 (permalink) Old 09-02-2011, 09:05 AM
joe
Make sure you lock that crank boys.
File Type: pdf Timing Chain tensioner replacemenat.pdf (989.8 KB, 59 views)
post #9 of 13 (permalink) Old 09-02-2011, 09:11 AM
Do you even want to tell us what you ride mate ?
post #10 of 13 (permalink) Old 09-02-2011, 11:36 AM Thread Starter
Thanks for the replies, I'm on a 910R. The central bolt is removed first and then the other two. The rattling noise that I thougth was caused by the chain tensioner wasn't, after removing it, it all seems good, 3 nothces out and no cracks at the roll pin connection....oh well at least I know it can't fail when I need it to be reliable. Hmmm... will need to track down that rattle.....valve clearances next! And yes, don't move that crank!
Claudio is offline
