Gas smell and liquid coming from left side hose - MVAgusta.net
post #1 of 13 (permalink) Old 06-09-2011, 09:19 AM Thread Starter
Went on a quick 5 minute ride from home just now and within minutes a hose that is positioned next to the waterpump but does not appear to be connected to the water pump that drains straight to the ground is shooting out what smells like gasoline.
it stops after shutting down bike but when you restart it it is a steady stream of what smells like gas, what is this?
is this the fuel tank overflow? if so why is it doing it even though the tank is not filled up to the brim? i checked the gas cap valve the other day and took it apart and put back together so that it would not clog, well the sound of the air esclaping is gone but now i have this new problem why is it doing it?
is this something to be concerned about?
its not a little gas it was like you had a fire hose on.
roadbiking is offline
post #2 of 13 (permalink) Old 06-09-2011, 10:36 AM
Exclamation
You have a burst hose mate, in the tank, where are you CA ? Carbon cannister ? To me it sounds like a hose in the tank. Dont ride it, strip it, and replace the hoses. Have a look Mate.
post #3 of 13 (permalink) Old 06-09-2011, 11:05 AM Thread Starter
talked to dealer he thinks it might be one of the vent hoses to the gas cap since the gas is coming out of that drain hose, geez this should be fun to do at work. lol
post #4 of 13 (permalink) Old 06-09-2011, 11:10 AM
Exclamation HHhhmm
Maybe not a burst hose, but only running out when bike is running ? Just open it up and check, you can't ride around like that !
post #5 of 13 (permalink) Old 06-09-2011, 11:18 AM
lewdog998's Avatar
Gas smell and liquid coming out back end....would have totally described Randy.
A gun is not a weapon. It's a tool, like a butcher's knife, or a harpoon, or an alligator.
lewdog998 is offline
post #6 of 13 (permalink) Old 06-09-2011, 12:12 PM
cdamb's Avatar
B750 and B1078 RR both gone now.
"Twenty years from now you will be more disappointed by the things that you didn't do than by the ones you did do. So throw off the bowlines. Sail away from the safe harbor. Catch the trade winds in your sails. Explore. Dream. Discover."~Mark Twain
cdamb is offline
post #7 of 13 (permalink) Old 06-09-2011, 12:14 PM Thread Starter
well will hav eto check later today but looks like the vent hose from the gas cap one of them is not there and fell off, so will have to reconnect that and see what happens then.
finally checked it out the one hose fell off or ripped right at the clamp at the gas cap, so have to figure out a way to get the hose out of the gas with a hanger and then tighten a hose clamp.
post #8 of 13 (permalink) Old 06-09-2011, 04:18 PM Thread Starter
if you remove the bottom of the tank where the fuel pump is and such do you have to reseal it? or is it just a rubber gasket?
the genuises at mv made the vent hoses hold on by clamps that you can't get off because they put it in such a way that the hose clamps you can't unscrew them from the opening where the gas cap is. only way to get to them is by taking off the tank.
post #9 of 13 (permalink) Old 06-09-2011, 09:06 PM
Post O-ring mate
Have a look here mate
http://www.mvagusta.net/forum/showthread.php?t=39000
post #10 of 13 (permalink) Old 06-09-2011, 09:13 PM Thread Starter
ok fixed it wasn't too bad but took some long needle nose pliers and a coat hanger and got it back on to the overfill barb which doesn't have a barb afterall, but its done now. what a hassle.
