Rear set torque...220Nm are the correct torque? - MVAgusta.net
post #1 of 65 (permalink) Old 06-07-2011, 09:31 AM Thread Starter
celica's Avatar
The last week I went to change the rear tire of my 990R and warned my mecha with the 220-240Nm torque of the rear set. He was not sure that this torque is correct because is a very high torque and it is not common in a bike rear set. Anyway, he decided to call the MV Agusta official mechas to get sure about this issue...and the answer was amazing. The MV official mechas told him to tighten the rear set as a normal bike (with a normal wrench and using the power of hand). Even, they told him NOT TO TIGHTEN the rear set with a 220-240Nm torque because in that case, the bolt can get sticked to the rear hub and there is no way to loose it later.
What do you think, guys?
Brutale 990R Black '10
Yamaha TMax '11
Husqvarna WR250 '10
(Previous: Honda CR250R '03, Yamaha FZ1 '06, Yamaha R6 '07)
celica is offline
post #2 of 65 (permalink) Old 06-07-2011, 10:11 AM
We've had several 'conversations' here on this subject. I don't see the need to go as high as 220 - 240 Nm, I torque mine to about 180. The circlip should stop the nut working loose in any case.
Keep one wheel down!
No MV's in the garage anymore
But...Ö..a new one is currently rising from the ashes......watch this space!
john is offline
post #3 of 65 (permalink) Old 06-07-2011, 10:16 AM Thread Starter
celica's Avatar
Yes, the circlip will save the situation in case of error...Now I have 110Nm torque in mine...and no problems at the moment.
Yamaha TMax '11
Husqvarna WR250 '10
celica is offline
post #4 of 65 (permalink) Old 06-07-2011, 06:48 PM
Thumbs down Too low
I really think 110 is too low mate, that is half of the factory spec, I would not go lower than 180nm, which is what I do mine upto.
post #5 of 65 (permalink) Old 06-08-2011, 02:57 AM Thread Starter
celica's Avatar
Next week I have to go to pass the 6K revision so I will talk with the MV official mechas to find out the truth of this issue...I will post here when get the answers.
Yamaha TMax '11
Husqvarna WR250 '10
celica is offline
post #6 of 65 (permalink) Old 06-08-2011, 03:06 AM
oldnfast's Avatar
Surely the truth is in the manual. The mechanics should not tell you any different. What others do to their own bikes is up to them, but I doubt an official MV machanic will tell you different from what the factory says.
I torque mine to 200 and have had no problems. Frank
oldnfast(ish) Racing towards old age
oldnfast is offline
post #7 of 65 (permalink) Old 06-08-2011, 04:55 AM
minime's Avatar
Until the circlip pops off and the wheels goes bye bye.
If you've got a proper torque wrench 220Nm is not that much. I can do it with one hand whilst the other hand is holding the 55mm tapered socket in place.
minime is offline
post #8 of 65 (permalink) Old 06-08-2011, 05:58 AM
Question
How is that clip going to pop out of the inside of the wheel ? I hace seen a few blokes where the nut had turned and pinched the clip though.
post #9 of 65 (permalink) Old 06-08-2011, 06:29 AM
firedancer's Avatar
unfortunately i did not make a picture of
my loose rear wheel nut with the twisted
and distorted circlip. but believe me it is
not a picture you want to see, especially if
you have just reached speeds up to 300 km/h
a few minutes ago.
firedancer is offline
post #10 of 65 (permalink) Old 06-08-2011, 06:35 AM Thread Starter
celica's Avatar
a few minutes ago.
Yamaha TMax '11
Husqvarna WR250 '10
celica is offline
