Help Please - anyone fitted new pipes to Brutale 1090RR - MVAgusta.net
post #1 of 7 (permalink) Old 05-25-2011, 06:32 AM Thread Starter
John M's Avatar
Has anyone fitted these Arrow Pipes to their Brutale 1090RR yet ?
http://www.motovationusa.com/mvstore/scripts/prodView.asp?idproduct=1109
They are similar to the Arrow Thunder for the older Brutale. According to the site, no changes are required to ECU etc. The CAT is gone and the O2 sensor is replugged into new pipe.
Would appreciate any comments.
MV Agusta F4 (2013)
John M is offline
post #2 of 7 (permalink) Old 05-25-2011, 08:48 AM
Alremc's Avatar
I believe with the removal of the cat and O2, you have to mod the ECU as there are electronic involved with there removal, well at least here in the states, not 100% bout Aussie models. good luck!
BTW, loved visiting your city/country, you all are awesome and very friendly folks!
Cheers, Frank
Frank
2010 MV 1090 Brutale
2012 HD CVO Ultra
2000 HD Ultra (Sold)
2005 MV F4 (Sold)
Alremc is offline
post #3 of 7 (permalink) Old 05-25-2011, 02:57 PM
billywhizzz's Avatar
I think Arrow make the MV corse decat pipe which is fitted to mine, I have the race ECU which doesn't need the lambda sensor and choke valve, the decat pipe has the provision to fit the lambda sensor so if you do that I am sure it will run ok, the choke valve mechanism will need to be connected to make the ECU thinks its still there.
K1300R
Diavel
Pushbike
billywhizzz is offline
post #4 of 7 (permalink) Old 05-26-2011, 05:52 PM Thread Starter
John M's Avatar
Thanks Guys for replies - much appreciated.
Billy thanks for advice - pulled exact same solution as yours from Arrow Technical Specs.
These pipes are orderd and will be fitted during my 1st service.
MV Agusta F4 (2013)
John M is offline
post #5 of 7 (permalink) Old 05-26-2011, 10:27 PM
Make sure you post up the pics when you get it installed. I have been wondering what that setup looks like mounted.
9ball is offline
post #6 of 7 (permalink) Old 05-26-2011, 11:02 PM
My buddy put the MV (Arrow) system on from the dealer. Look and sound amazing.
I'm almost certain it came with an ECU though???
'02 88" Sportster
'10 BMW F800R
'10 Brutale 1090R "Soon"
canicoll is offline
post #7 of 7 (permalink) Old 05-29-2011, 02:06 AM Thread Starter
John M's Avatar
9ball - will do
MV Agusta F4 (2013)
John M is offline
