1090 Mirror Question - MVAgusta.net
post #1 of 22 (permalink) Old 09-22-2010, 02:59 PM Thread Starter
Those of you with 1090s, Have any of you replaced the mirror/TS pair and replaced them with either different mirrors or Bar Ends? It looks to me like the base of the stock mirror mount is a cast part that is also the lever perch and the master cylinder.
What did you do to clean this up????
Mark
brooksr13 is offline
post #2 of 22 (permalink) Old 09-24-2010, 04:46 PM
Hi
Removed my mirrors and relocated the indicators onto the headlight bracket. Fitted a set of rizoma radial naked mirrors. IMO it has improved the look, got rid of the annoying buzzing and given me mirrors that actually work.
flushman is offline
post #3 of 22 (permalink) Old 09-24-2010, 05:33 PM Thread Starter
Removing Mirrors
When I looked at removing the stock mirrors it looks like the mirror base and the lever perch and the master cylinder are all one casting. Did I miss something????
post #4 of 22 (permalink) Old 09-25-2010, 04:58 AM
No your right. Remove rubber cap and unbolt mirror stalk and your left with the bolt sticking out of the cast unit. Rizoma do mirrors that attach to that bit using their fitting kit. No one does a set with integrated indicators so you will need to decide what to do about the indicators. Oberon do a set of bar end indicators or its a case of relocating a set of aftermarket ones on the headlight bracket.
flushman is offline
post #5 of 22 (permalink) Old 09-25-2010, 11:54 AM Thread Starter
Oh. So that is what the fitting kit is for, Makes perfect sense now. Already have a set of Oberon just need the adapters for this sized bar. Pictures when this project is finished.
Mark
post #6 of 22 (permalink) Old 09-25-2010, 07:33 PM
I was considering the oberon and rizoma as well so look forward to the pics. I also ordered the Barracuda mirrors with integrated signals...I know they don't fit but I plan to see what I can do to remedy that in the machine shop.
slyfox is offline
post #7 of 22 (permalink) Old 09-28-2010, 05:11 AM
Totale's Avatar
If you fit Bar-ends you can tidy up by replacing the mirror mount plate with these
http://www.vesuvioracing.com/MV-Agus...nit--2194.html
Totale is offline
post #8 of 22 (permalink) Old 09-28-2010, 10:07 AM Thread Starter
Thank You
Thanks Totale,
I didn't realize that those were available, Now I have to choose between the Rizoma Naked or the Bar Ends. Does anyone have experience with this choice, I'm looking for visibility here not Bling.
Mark
post #9 of 22 (permalink) Old 09-28-2010, 10:11 AM
Totale's Avatar
Bar ends every time if you want mirrors to see with! - just can't remember which ones were on the demo bike - will try and find pic for you.
Totale is offline
post #10 of 22 (permalink) Old 09-28-2010, 10:25 AM Thread Starter
CRG Arrow or the Rizoma Reverse Retro seem to be the ones I see the most.
Mark
