2006 MV Agusta Brutale 750 - Problems to expect? - MVAgusta.net
post #1 of 15 (permalink) Old 07-04-2010, 02:54 AM Thread Starter
xeorex's Avatar
Hi,
Now that I am getting a 2006 MV Agusta Brutale 750cc (1000 miles on the counter), what are the problems I am likely to encounter on this model over its lifespan?
In other words, what is it I particulaly need to pay attention to in order to have a overall lasting good experience with it?
xeorex is offline
post #2 of 15 (permalink) Old 07-04-2010, 04:48 AM
cruiser's Avatar
Search for SPU (Service Power unit), sometimes an issue (luck of the draw with these)
Four year old model with less than a 1000m - would change all fluids - potentially have rear Eccentric hub bearings checked (main bearing being the more at risk one....the pin roller less so)
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is online now
post #3 of 15 (permalink) Old 07-04-2010, 09:22 AM Thread Starter
xeorex's Avatar
Thank you for your tips.
Do you think I could at least ride it home before doing these?
Thoughts about best fluids to get?
xeorex is offline
post #4 of 15 (permalink) Old 07-04-2010, 04:21 PM
cruiser's Avatar
Absolutely bud...!!
SPU - read the threads so you can recognise the symptons - (IF) it's going to happen, there's nothing you can do to stop it...just a design flaw in the early models that sometimes occurs and sometimes not
Fluids - Seach on best oils, break fluids etc (the water reserve is under the key guard..yes you need to remove the key guard to get at it if required)
All I can say is that MV's should be ridden and not stored for the once every 8 week special ride...they do run better when they're being used !
...and welcome to the family
Tim
Current
Past
post #5 of 15 (permalink) Old 07-04-2010, 04:22 PM
greminn's Avatar
+1 on both these!
Cheers, Simon
Brutale 910R
greminn is offline
post #6 of 15 (permalink) Old 07-05-2010, 03:55 AM Thread Starter
xeorex's Avatar
Thanks a lot
xeorex is offline
post #7 of 15 (permalink) Old 07-05-2010, 04:13 AM
Ehcor's Avatar
Buy a good torque wrench if you don't already have one, then make sure all the nuts and bolts are tightened to manufacturers specification - Not over tightened.
Pay particular attention to the Hub Centric Bolts, always make sure they are tightened to the correct tension after adjusting the chain.
I changed the rear hub bearings at 35,000KM as a precaution, travelled 42,000KM and never had a problem with the Brutale.
Enjoy
Ehcor is offline
post #8 of 15 (permalink) Old 07-05-2010, 04:36 AM Thread Starter
xeorex's Avatar
Enjoy
I haven't got a torque wrench but was thinking getting one.
I am not familiar with quality brand tools in UK. I don't see the ones I used to be familiar with. Any suggestion for one of these will be greatly appreciated.
I heard cheapish torque wrench can sometimes give you a torque a bit off from what you were expecting.
xeorex is offline
post #9 of 15 (permalink) Old 07-05-2010, 06:14 AM
cruiser's Avatar
roughly 150-175BPS is the right figure
Tim
Current
Past
post #10 of 15 (permalink) Old 07-05-2010, 09:38 AM
Hey congrats on the purchase. I had a stalling problem when I picked up my bike. I feared the worst when it started stalling but it turned out that it was just a tuning issue and was easily sorted out. This could have happened as the bike was sitting for a while before I bought it. So I went ahead and had all the fluids changed and never had a problem since. Enjoy the ride.
Sarge
Sarge is offline
