Headlight - MVAgusta.net
post #1 of 14 (permalink) Old 04-13-2010, 09:04 AM Thread Starter
Headlight
I recently installed a HID low beam, it worked great for awhile, but now stopped working entirely. I know that the bulb still works, since when I change it from low beam to high beam in comes on for a brief moment...could a relay have gone bad or the headlight switch? Thx.
CodeRed is offline
post #2 of 14 (permalink) Old 04-13-2010, 12:12 PM
JDS
King of Bling
JDS's Avatar
Send a message via MSN to JDS
Send Woodster a PM as he is the Main Man when it comes to HID kits and problems .
EMAIL :
JDS is offline
post #3 of 14 (permalink) Old 04-13-2010, 12:42 PM Thread Starter
I didnt see any woodster on the members list...
CodeRed is offline
post #4 of 14 (permalink) Old 04-13-2010, 01:07 PM
MihaSLO's Avatar
MihaSLO is offline
post #5 of 14 (permalink) Old 04-13-2010, 08:15 PM Thread Starter
^ Thx, I sent a PM earlier today..so hopefully I can find out the issue.
CodeRed is offline
post #6 of 14 (permalink) Old 04-14-2010, 10:42 AM
cnegron's Avatar
Where is your ballast and igniter in relation to the bulb? The ballast sends a pulse signal to fire the bulb before sending a steady voltage. If the ballast is close to the bulb, I imagine it might have gone bad internally, however those things are pretty solid. I would find out if there's a bad ground connection that may have "tweaked" out the ballast. Where did you get the HID kit from?
cnegron is offline
post #7 of 14 (permalink) Old 04-14-2010, 01:13 PM
G.Rand's Avatar
Richard -- the easiest thing to do would be to check and see if you still have 12v + to the ballast. Wanna swing it by and we'll take a look at it?
G.Rand is offline
post #8 of 14 (permalink) Old 04-14-2010, 03:47 PM Thread Starter
Yep, I will get in touch soon. Thx.
CodeRed is offline
post #9 of 14 (permalink) Old 05-26-2010, 04:04 AM
svldvc's Avatar
I have a same problem....did you ever figured it out???...
~Serge~
svldvc is offline
post #10 of 14 (permalink) Old 05-26-2010, 09:58 AM Thread Starter
It was a bad bulb
CodeRed is offline
