Gear flange disengaged while riding - faulty clip? - MVAgusta.net
post #1 of 11 (permalink) Old 04-11-2010, 03:38 PM Thread Starter
Buck's Avatar
Hi guys. Was riding today when all of a sudden noticed how the brute was slowing down gradually until coming to a complete stop. Turned out the gear flange thing assembly decided to come off the bike. Went a couple hundred meters back and found it lying on the road but didn't find the nut though. Luckily the wheel itself stayed with the bike while it was happening.
So well, the question is could a faulty clip be responsible for a loose nut in turn leading to this? A repairman says it could only happen if somebody intentionally pulled a clip out of the wheel and says it's quite easy to do so on the left side where the chain is, yet other folks suggest the clip itself could break which is also plausible given that I've been riding some rough roads lately (with a passenger too).
I want to understand why it's happened. Has anyone else seen or heard of anything like that?
Buck is offline
post #2 of 11 (permalink) Old 04-11-2010, 04:14 PM
Yep it can happen.
Kiwidoc is offline
post #3 of 11 (permalink) Old 04-11-2010, 06:23 PM
greminn's Avatar
I had the wheel nut come loose on me, not acually come off like you guys, but the shop had not installed the clip correctly in the wheel and not toqued the nut correctly either.
The clip could certainly shear off given enough forces i would think? However, has the rear nut been off lately? If so, it has not been done up correctly.
Simon
Cheers, Simon
Brutale 910R
greminn is offline
post #4 of 11 (permalink) Old 04-11-2010, 06:24 PM
greminn's Avatar
Originally Posted by Kiwidoc View Post
Yep it can happen.
Ahh - your lady told me the story of this one! phew!!
PS: Good to see you guys yesterday
Cheers, Simon
Brutale 910R
greminn is offline
post #5 of 11 (permalink) Old 04-12-2010, 01:36 AM
Oh my!!!! holy crap... This could just killed you....
I think better send the pic to MV Agusta to ask if there is any design defect.
jackie-MV is offline
post #6 of 11 (permalink) Old 04-12-2010, 01:42 AM
greminn's Avatar
Dont get this thread started... my 312 wont do 312!
Cheers, Simon
Brutale 910R
greminn is offline
post #7 of 11 (permalink) Old 04-12-2010, 01:56 AM Thread Starter
Buck's Avatar
Well, I've had chain adjusted a week or two prior to this. Thanks for the clues!
Kiwidoc, do you have any idea what could've triggered that in your case?
And how long do you guys think it could've normally taken from, say, sloppy tightening/missing clip to this nut actually coming loose?
I just don't want to blame the repair guys just yet even though some say it's definitely their fault...
All this makes me wonder what part will come off next. Hope the bearing is OK...
Buck is offline
post #8 of 11 (permalink) Old 04-12-2010, 04:15 AM
This is nothing, next you have to face issues with the hub, followed by PSU problems, then there will be the oil leak from the side stand. I just got used to all the issues. Also avoiding builtup areas helps with the cutting out. Oh and dont wash it very often .
Great machine otherwise. You have to say that tho , or else people will never want to buy a second hand one, or out of waranty for what that's worth.
Seriously tho my sprocket problem was 1500km after its "FIRST" hub check at 48,000km. I suspect it was something to do with not using loctite. I had cable tied the clip on even.
Kiwidoc is offline
post #9 of 11 (permalink) Old 04-12-2010, 05:34 AM Thread Starter
Buck's Avatar
But I've already had hub problems right before this happened - in November last year at 12000 km. All of a sudden the wheel rim started rubbing against the swinging arm but I've suspected some improper nut tightening at the service station some 6000 km before that could've slowly damaged it. But then a lot of people seemed to complain about hubs getting broken for no reason at all if memory serves me right. Replaced the hub, winter passed and 1000 km later this happens. Did you tighten it all the way? It just doesn't seem right. I didn't use any loctite either but that's not a requirement, right?
Buck is offline
post #10 of 11 (permalink) Old 04-12-2010, 02:36 PM
Im using the loctite because I never had any problem before the hub was checked. We had to heat the nut to get it off. I assume that they used loctite at the factory. Just something you have to pay attention too now. Always checking the wheel .
Kiwidoc is offline
