2007 R vs 2006 S - MVAgusta.net
post #1 of 13 (permalink) Old 10-22-2019, 11:21 PM Thread Starter
2007 R vs 2006 S
hey quick question
i had a 2006 S that i enjoyed however it had a major flaw....rolling on the throttle mid corner. i could never get it smooth. it ruined the experience somewhat. i'm thinking about an 07 R. is this basically the same motor/computer with the same characteristics?
thanks
dougn is offline
post #2 of 13 (permalink) Old 10-23-2019, 06:00 AM
R1andrew's Avatar
My 2007 1000R had the 5,000 surge in power. It was like a turbo kicked in. I enjoyed it, but not cornering on a track at times. Their are ways to adjust that now.
MV Agusta F4 Superleggera (Mona Lisa)
MV Agusta F3 Ago 2015
MV Agusta F4 1000 Senna #25
Ducati 1098 2009
R1andrew is offline
post #3 of 13 (permalink) Old 10-23-2019, 07:19 AM
Originally Posted by dougn View Post
hey quick question
thanks
Since this is in the Brutale section I am going to guess the F4 references above are not what you were looking for.
The 2006 Brutale 910S has the old 1.6M ECU which is notorious for really poor fueling if not properly tuned. A chip can remedy this to a point.
The 2007 Brutale 910R has the 5SM ECU with sequential injection. Massive improvement in fueling, but still not perfect in stock trim.
There are ways to improve both, but the 2007 R is easier and the bike enjoys other upgrades as well.
The major differences in the bikes (other than the ECU) are in chassis upgrades. The engines are mechanically the same.
The 2007 is Euro2 compliant as well, which means headers and mid-pipe/cat are one piece and a second air system is added (does not affect performance).
post #4 of 13 (permalink) Old 10-23-2019, 09:34 AM
That flat spot response can be tuned out of the 5SM ECU.....
post #5 of 13 (permalink) Old 10-23-2019, 10:57 AM Thread Starter
yes i was wondering if it had a different ECU. there is still a removable eprom i guess because the seller says he has the mv "racing" chip. i wonder if the roll on jerkyness above 5k rpm is better behaved? what is sequential FI?
dougn is offline
post #6 of 13 (permalink) Old 10-23-2019, 03:25 PM
2007 Brutales 910R still had 1.6M ECU in the USA. Our market was a year behind.
2007 910R and 9 other bikes
pittmeister is offline
post #7 of 13 (permalink) Old 10-23-2019, 07:57 PM Thread Starter
if i could get a 5SM ECU, is it plug and play?
dougn is offline
post #8 of 13 (permalink) Old 10-23-2019, 07:59 PM
You cannot replace a 1.6M with a 5SM.
You can contact @merc07.
post #9 of 13 (permalink) Old 10-23-2019, 10:09 PM
Actually...we got no 2007 Brutales in the USA.....we got the Euro 2007 as a 2008 model (with the 5SM).... So I was assuming he was in other markets where the 2007 was Euro2 with the 5SM.
So just where on the planet is @dougn located? It's not in your profile???
Regardless....if the owner says the 910R has a "chip" then it is the 1.6M ECU.
Sequential injection means the injectors fire only on an intake stroke. The old 1.6M fires injectors in pairs (and spark plugs, but that's no big deal).
So the injection is not sequential (following intake strokes on each cylinder in sequence), and actually squirts fuel against a closed intake valve in a stagnant air stream on the cylinder that is not on intake stroke (on power stroke).
The 1.6M ECU is basically a twin cylinder ECU.
So in this case there is no value or difference in the engine performance between the subject 910S and 910R...just chassis. Although the 910R of that vintage did come withe the "Kit exhaust and ECU chip included in the crate at no extra charge.
The Euro2 with 5SM did not come with the exhaust and ECU in the crate (and had a lower MSRP as well).
post #10 of 13 (permalink) Old 10-23-2019, 11:55 PM Thread Starter
i'm in the US (california)
i couldn't imagine the injectors would fire a half cycle early....wow. it's a wonder it works as well as it does.
that's too bad. i like everything about them except for the off on throttle jump. it's impossible to transition smoothly
what about the 06 F4? there's some nice ones out there. are they abrupt too?
dougn is offline
