Is this the right header for my bike ? - Page 2 - MVAgusta.net
 5Likes
post #11 of 17 (permalink) Old 09-11-2019, 11:59 AM
falcn's Avatar
Originally Posted by tweav View Post
Yes the GPR slip on is removed it was too loud . I put the stock cans on it the second day I had it . I guess I will sell the slip on some time .
Yeah I feel you (and my CAT heat ) it does throw off some heat. I've thought about changing mine too, but that requires a new header and mid-pipe, and ECU or ECU tuning...Maybe next year.
The interesting topic going on in parallel here is the 910 header on 1090RR thread. A member is throwing a 910 header on his 1090RR and attempting to use a mid-pipe with the stock exhaust cans. I am waiting to hear the results.
falcn is offline
post #12 of 17 (permalink) Old 09-12-2019, 06:37 AM Thread Starter
tweav's Avatar
I am really wondering if I can just fatten up the ecu map by readjusting the tps sensor on my buddies dyno with the o2 sniffer in the pipe . the healtec and the pipe are now ordered , I will worry about the tune when I get there
tweav is offline
post #13 of 17 (permalink) Old 09-12-2019, 10:05 PM
Nope, I'm sending Tim stock 910 head pipes to go with an Arrow Thunder system on his track bike
The head pipes that were on the track bike aren't stock, but they fit over the counterbalancer bump
on the cases
post #14 of 17 (permalink) Old Yesterday, 07:59 AM Thread Starter
tweav's Avatar
Well...no I'm not anymore. I thought the ECU changed after 2012 like it did on the F4 models, but I haven't seen a parts catalog for any recent B4 models... now I see the 2013 shows 5SM.....so ?????
OK...Then Microtec does have a replacement for you !!! OR....I believe @silentservice703 has a tuner who has cracked the 5SM for tuning. Tell your dyno guys to reach out to him.
So then is the microtec m226 the right ECU ???? What happens with the ABS ????
falcn likes this.
tweav is offline
post #15 of 17 (permalink) Old Yesterday, 11:49 AM
falcn's Avatar
on the cases
I wasn't referring to Tim. As Yoda said..... "There is another...."
falcn is offline
post #16 of 17 (permalink) Old Yesterday, 03:03 PM
The ABS system is it's own computer, contained in the ABS unit (pump)...at least on most bikes that don't also use an Inertial Measurement Unit for cornering ABS and such....
You should ask Chris at X-Bikes about Microtec.
post #17 of 17 (permalink) Old Today, 02:07 AM
bogie's Avatar
Chris at X-bikes will tell you there is no Microtec solution if you have ABS
...so you have to look at other aftermarket solutions for mapping
cheers
bogie
_________________
2015 Brutale 1090RR
bogie is offline
