1090RR clutch master cylinder rebuild kit? - Page 3 - MVAgusta.net
 5Likes
post #21 of 23 (permalink) Old 04-08-2019, 06:07 AM
The M/C and slave springs have nothing to do with lever pressure......
It's all about the ratio of the bore diameters and the springs in the clutch
post #22 of 23 (permalink) Old 04-08-2019, 10:13 AM
Originally Posted by Rcka View Post
The spring won't change the feel so much...that is a function of the clutch springs and hydraulic pressure generated by the ratio of master to slave cylinders.....but if the spring is preventing full movement of the master piston you will not get full movement of the slave.
As usual, esq'z me is right. The clutch springs are substantially stiffer, and the ratio of diameters of the master to slave determine the mechanical advantage. The master spring is just enough to overcome the internal friction and the spring on the clutch switch.
[IMG class=inlineimg]https://www.mvagusta.net/forum/images/MVagusta_net_2016/smilies/tango_face_wink.png[/IMG]
As I'm getting pieces switched and taking measurements, please advise on the purpose of the MC & Slave springs. 🐣
fkhan is offline
post #23 of 23 (permalink) Old 04-09-2019, 02:25 PM
Currently have:
Clutch MC piston seals replaced.
Original piston and spring installed.
Slave cylinder seals replaced.
New clutch plates.
Currently when moto is in 1st and clutch pulled in it was difficult if not impossible to turn wheel.
I noticed when bleeding system the amount of fluid is less than previously noticed.
Any ideas?
fkhan is offline
