2005 Brutale transmission problem - MVAgusta.net
 10Likes
post #1 of 28 (permalink) Old 09-03-2018, 11:18 PM Thread Starter
tallguyjc's Avatar
Hey all, new member here so some quick background. I found a 2005 B4 Brutale 750 that I was able to pick up for $3,300 last week. Got it home and just did a quick ride and it went really good. Got up the next day and had some oil leaks, I still need to take care of those. I have two gaskets that need to be replaced, so if anyone can let me know a good site to get,them from that would be awesome. So I top,off the oil, and take it out for its maiden voyage with my brother on his bike. We are only gone for about 15 minutes and then the problem with the transmission started. I took off from a stop in 1st, went to shift into 2nd, and it wouldn't go. It would go into neutral, but 2nd was not happening. The gear lever would not go up. I had to downshift and ride home in 1st, which caused the bike to run hot being stuck in that gear. Everytime I go to ride this happens. The bike will go back to normal after about a 10 minute cool down and it works fine again, for a little bit. Does anyone happen to know what might be going on with it? I have no ideas. I also contacted my local repair shop about it, but they have next to no experience with MV so they said they couldn't do anything with it. Other than these issues, I absolutely love this bike and plan on having it for a long time...if I can get the transmission working properly.
tallguyjc is offline
post #2 of 28 (permalink) Old 09-04-2018, 12:52 AM
cruiser's Avatar
We might need a bit more data to help you out TG.
Does the bike shift gears up when it's not running, clutch in rolling the rear wheel ?
Does it only happen when the bike is hot ?
Has his just occurred or does it return to normal service when the bike is cold?
Has anyone removed the front sprocket cover recently?
How many km's has the bike done?
Where are you on the planet?
...and on a different but vital vein, please confirm you have the rear hub checked by someone in the know and serviced? (removed, cleaned and re-greased)
Tim
Current
MV Agusta Brutale 1090RR
Past
MV Agusta Brutale 750s
cruiser is offline
post #3 of 28 (permalink) Old 09-04-2018, 02:20 AM Thread Starter
tallguyjc's Avatar
Below are the answers to the questions.
Does the bike shift gears up when it's not running, clutch in rolling the rear wheel ? Yes, but it has to cool cool down but if it ia cold, it has no issue.
Does it only happen when the bike is hot ? Yes, if the engine is cold it will go into any gear without issue.
Has his just occurred or does it return to normal service when the bike is cold? I've only had the bike for a total of 4 days. I have asked the previous owner, he said he never had a problem. The title is clean, and from 2014 to the time I bought it, it has only been driven about 2,000 miles. It has 25,300 miles on it currently. I do not think this bike was abused, it came with the manual with all the little sheets about adjusting the suspension, accessing the battery, the CD Rom that was sold with it, a battery tender, wheel lock and cover. The oil is clean as well.
Has anyone removed the front sprocket cover recently? To my knowledge, no it has not been removed.
The bike has 25,300 miles on it.
Where are you on the planet? I am in Bakersfield, California...aka, hell.
...and on a different but vital vein, please confirm you have the rear hub checked by someone in the know and serviced? (removed, cleaned and re-greased) I have not had this done, but I will have it looked at. Thank you for the advise.
I hope that answers your queations, if there is anything else you need me to provide, please ask. Thank you for the help.
post #4 of 28 (permalink) Old 09-04-2018, 03:45 AM
Deano's Avatar
Time to remove the gear selector cover and check the springs, the main shift and the small pawl springs. If the main spring was broken then it wouldn't return to normal when it cooled, it'd be stuck in whatever gear it was in when the spring broke. So I'm betting on the smaller pawl springs in there. Other than this I can only think selector or something else in the box that's seizing when hot. Seems strange when the previous owner had no problems but when shit goes wrong it goes wrong.
Manuals are here for downloading: - Forums/Tech tips and resources for ALL models. Also there are links to how to do the job. There is an especially good one by Eddiepro with full pics.
If you have any mechanical skill it's pretty easy, just time consuming. Need to drain oil and coolant. Parts can be had from the marketplace here but I usually use StarTwin Trading in Belgium.
Deano
theknurl and lefin102 like this.
2009 1078RR Brutale
Deano is offline
post #5 of 28 (permalink) Old 09-04-2018, 05:55 AM
Since it is only when hot I would think your clutch needs a good fluid flush and thorough bleeding!! Start with that. And flush and bleed your brakes, too. I'll bet the hydraulic fluids are very old and nasty.
Where are you ???
post #6 of 28 (permalink) Old 09-04-2018, 09:22 AM Thread Starter
tallguyjc's Avatar
Thank you for the help guys. Ill have my work cut out for me this next weekend. Also, I'm in Bakersfield, California.
post #7 of 28 (permalink) Old 09-04-2018, 09:30 AM
Add that to your profile !
Seriously, I would do the fluid flush and bleed before anything else. With the age of the bike (and the general maintenance habits of Americans in my experience) I believe that could be your only problem.
Quality engine oil helps with smoother shifts, but the MV transmissions are not known to have problems. Clutch hydraulics, on the other hand, can cause shifting problems.
lefin102 likes this.
post #8 of 28 (permalink) Old 09-04-2018, 10:16 AM Thread Starter
tallguyjc's Avatar
Thanks for the info. I didn't see a place to add my location in the profile settings. I'm doing this all from my phone, so maybe it is different on a computer.
post #9 of 28 (permalink) Old 09-04-2018, 10:22 AM
User CP is the place to edit profile and add signature etc
post #10 of 28 (permalink) Old 09-04-2018, 08:36 PM
tallguyjc;
Get some Clic-R pliers off eBay ~$12 last time I looked
Do a service on all fluids and both filters
The best oil filter is a Purolator PL-14612 available at Pep Boys in Bakersfield
The wrench for the filter (late blue ones) Hopkins 10605 Super Graphite Filter Wrench #5
The fuel filter is a WIX #33012 available at O'Reilly in Bakersfield
While inside the tank replace the 5/16" SAE J 30 R 10 submersible fuel line, it's sold in a 1 foot piece, you won't need all of it
One of your oil leaks is probably the left rear of the pan gasket.....remove the side stand and correctly torque the pan bolts
The other ones are either or both the valve cover or the F4 cover.....buy some Permatex Form-a-Gasket
Loosen the pinch bolts on the swing arm and retorque them to 15lbft/20Nm when adjusting the chain, ignore the sticker
in fact remove the POS
I've been building manual transmissions for a long time........It's not heat related.....I'm with Deano, the pawl spring or shit inside the ratchet drum.....simple to check, and if it's broken cheap to fix
You have questions? Call me.....text me 1st, my phone doesn't allow unknowns
