Seperating the handlebars from riser clamp brutale 910r - MVAgusta.net
post #1 of 8 (permalink) Old 03-09-2016, 09:35 PM Thread Starter
rizthefiz's Avatar
Hello everyone,
I am in the process of changing my stock handlebars to that of the s4r. but my bars seem to be screwed on to the top of the riser clamps. How do I detach it? I have uploaded an image showing the part. "number 17"
http://imgur.com/eLz1qBa
any help would be greatly appreciated.
Thanks!
rizthefiz is offline
post #2 of 8 (permalink) Old 03-09-2016, 09:56 PM
Sydney 910R's Avatar
Hey rizthefiz,
I did the exact same mod on my 910R several years ago, as far as I'm aware its not screwed but more like a locating pin to make sure you have the center of the bars, like on your clutch or throttle assembly there will be a pin that locates them to the bars. You should just be able to tap the clamp away from the bars carefully with a rubber hammer.
James
Sydney 910R is offline
post #3 of 8 (permalink) Old 03-09-2016, 10:00 PM
Deano's Avatar
Tap it! Then you have to remove all pins etc. from the bars and switch blocks.
Deano
Deano is offline
post #4 of 8 (permalink) Old 03-09-2016, 10:00 PM Thread Starter
rizthefiz's Avatar
Thanks James!
It seemed like it was stuck on there pretty good. I will have a go at it later tonight and let you know how it goes. Also, did you have to drill in new holes on the bar to accommodate the clusters?
post #5 of 8 (permalink) Old 03-09-2016, 10:02 PM Thread Starter
rizthefiz's Avatar
Thanks Deano!
how do i remove all the pins? just yank them off with a pair of pliers?
post #6 of 8 (permalink) Old 03-10-2016, 01:09 AM
Deano's Avatar
Yep! They twist out pretty easy. The clamp diameter is a pretty close fit to the bar diameter and it really jambs the bar in, either the top or bottom clamp. Doesn't seem to be a problem on aftermarket bars. I have Rizomas.
Deano
Deano is offline
post #7 of 8 (permalink) Old 03-10-2016, 12:51 PM
number2's Avatar
Originally Posted by rizthefiz View Post
Thanks James!
You might want to consider lifting some weights
number2 is offline
post #8 of 8 (permalink) Old 03-12-2016, 03:05 PM
Wink ?
1 ounce of RDX should do it.......
