Upshifting problems - MVAgusta.net
post #1 of 16 (permalink) Old 06-28-2015, 01:04 PM Thread Starter
Upshifting problems
Hi! I have Brutale 989R. At the end of last summer I noticed that upshifting to fifth or sixth gear does not always go smoothly and now it does same thing again. Seems like it does not found right place to turn gear on.
When I shift and release clutch it stays on neutral ~1sec and then gear goes on. It does not do this always.
Couple times gearbox has rattled when upshifting to 5th or 6th even tough I have clutch on - just like it gould not get right gear on.
Any thoughts what could cause this?
989R
hene is offline
post #2 of 16 (permalink) Old 06-28-2015, 08:33 PM
eddypro's Avatar
Bleed the clutch fluid and change to a different oil in the motor
eddypro is offline
post #3 of 16 (permalink) Old 06-29-2015, 01:38 PM Thread Starter
Hmm, okey. Have to try that. Which oil have you used? Right now I have Castrol Power 1.
Is there anything unusual of bleeding the clutch in MV?
989R
hene is offline
post #4 of 16 (permalink) Old 06-29-2015, 05:19 PM
eddypro's Avatar
Use a fully synthetic oil ,I use Castrol also but not power 1,In my part of the world it works great.How many miles has the bike done .Bleeding is straight forward,
Try Mobil 1 ,there are many threads on here about oil,just do a search
eddypro is offline
post #5 of 16 (permalink) Old 06-30-2015, 06:08 PM
Miko's Avatar
It's sometimes happening to me on my B-750 between 5th and 6th gear, but only during "normal" shifting.
Possible ... khmmm ... solution.
I usually use "clutchless shifting" and I noticed that never had problem of false neutral in that riding mode.
Try it, maybe You'll love it
Miko is online now
post #6 of 16 (permalink) Old 06-30-2015, 07:21 PM
Bleeding your clutch will make no difference in your case, oil change might. Try what Miko suggested, and also try dropping your gear lever toe piece. As you go through the gears the lever moves upwards ever so slightly, dropping the lever might give you a slightly better shift position.
Eddy, I got that Optimiser yesterday, thanks mate, will let you know how they go with it.
post #7 of 16 (permalink) Old 06-30-2015, 10:13 PM
Thumbs up false neutral......
hene;
like Miko said shift without the clutch.......once you get used to it .......
you'll ask yourself why you didn't do it sooner
remember POSITIVE movements of the lever
post #8 of 16 (permalink) Old 10-17-2015, 10:12 PM
aagostini's Avatar
Check for leaks on the secondary clutch pump. This piece is located left side of engine
aagostini is offline
post #9 of 16 (permalink) Old 10-18-2015, 03:20 AM
It's called a clutch slave cylinder.
post #10 of 16 (permalink) Old 10-23-2015, 03:57 AM
abadirr's Avatar
"shift without the clutch" Have tried it since, and I like it. Thanks guys for these info. but is there any problems that it may cause to the gearbox?
Cheers,
abadirr is offline
