New 910 owner - need the basics - MVAgusta.net
post #1 of 13 (permalink) Old 04-21-2015, 10:45 PM Thread Starter
Dduck's Avatar
I have long admired the brutale and now I have added one to my stable to go with my fz1 and HD.
The bike I'm buying has arrow exhaust but stock ecu. I see many different ecu options. Do I get a new ecu or just a chip, or chip and power commander?
Then there is another thing called an SPU. I'm assuming that is a completely separate part that will need to be replaced if it is blue instead of black.
Then there is the Mitch Hub, how unsafe is this bike if I don't install this part. Seems to be expensive but a no brainer if it is a safety concern.
Thank you
Dduck is offline
post #2 of 13 (permalink) Old 04-22-2015, 02:54 AM
Welcome to the forum Dduck.
Firstly you have to figure out which model you have, then which year - 910S or 910R - EURO 2 or EURO. This will determine which SPU and ECU your bikes uses.
Have a read through some of the topics in this section - http://www.mvagusta.net/forum/showth...69#post1361569
Have a look through the maintenance section, heaps of discussions on the hubs, basically it come's down to this, if you cant say what's been done on it, and you can't maintain it confidently, then buy one of the better hubs.
post #3 of 13 (permalink) Old 04-22-2015, 04:37 AM
agusta 17's Avatar
Is that capital D for Darkwing? "When there's trouble you call DW"
MV Ultra Take the ride!
agusta 17 is offline
post #4 of 13 (permalink) Old 04-22-2015, 06:54 AM
Welcome to the family Dduck!!!
As for ECU options....does it run well?? Yes?, leave the ECU alone.
Take the rear hub apart. Inspect it and replace the bearings if all looks good. Then maintain it correctly. Replace it if there is any damage at all.
SPU is the fuse/relay box on the right side of the tank. Easy enough to see if it is the new improved part or the old failure prone one.
Great bikes!! Enjoy your new ride!
post #5 of 13 (permalink) Old 04-22-2015, 08:20 PM
Big Randaddy
Randarosa's Avatar
The Basics: You bought the pinnacle of Brutale production. There will be the naysayers that believe that the ugly younger brother 1078 is the top banana, but don't believe it. The 910R rules the roost.
The second generation Brutales, all of them, as nice as they are in their own right, don't compare to the first gen 910.....
One other thing......Chicks dig Brutie Riders.
Randarosa is offline
post #6 of 13 (permalink) Old 04-22-2015, 08:57 PM Thread Starter
Dduck's Avatar
Thank you for the warm welcome. Bike being shipped to me in FL from NY so I haven't riden yet. Seller says on off throttle a bit choppy with the arrow exhaust install. 2006 910s is the model.
I drove a newer brutale 2013 and loved it but didn't want to spend $12k-$13k on a third bike. The 910 is sick and even more raw from what I've read. Which is exactly what I want, a wild sexy bike for short flings...
Luckily I have a great ducati mech that also knows MV's but still want to be informed.
Dduck is offline
post #7 of 13 (permalink) Old 04-22-2015, 09:15 PM
Deano's Avatar
Dduck,
Welcome. Choppy with or without the Arrow. Something to get used to with a bit of clutch help.A different ecu smooths this out a bit but they are a very sensitive throttle. I run a Microtec from Chris at XBikes. Big improvement but don't try the loud button down low if your clutch hand isn't in place.
Deano
Deano is offline
post #8 of 13 (permalink) Old 04-22-2015, 09:58 PM Thread Starter
Dduck's Avatar
Originally Posted by Deano View Post
Dduck,
Deano
What is the loud button? Are you talking about a hand full of throttle? Made that mistake on a gsxr1000 once. And on a 2 stroke dirt bike that literally put me on my back going down a 45 degree hill.
Will check out Xbikes. Thx
Dduck is offline
post #9 of 13 (permalink) Old 04-22-2015, 10:33 PM
I think I know this bike. Wait until you get it before you start throwing money at it. You may only require an adjustment to the TPS.
post #10 of 13 (permalink) Old 04-23-2015, 03:59 AM
Deano's Avatar
Yep, that's what I'm talking about.
Deano
Deano is offline
