Underseat charger plug - MVAgusta.net
post #1 of 12 (permalink) Old 03-29-2015, 11:45 PM Thread Starter
KingKole02's Avatar
So, I understand per this documents and FAQ section, that the plug under the seat is for a charger. I did not get a charger with my bike.
http://www.mvagusta.net/docsandfaq.php
Anyone know where to purchase? I could wire a battery tender but I'd like to use the one provided if possible.
KingKole02 is offline
post #2 of 12 (permalink) Old 03-30-2015, 01:08 AM
The provided chargers are not the best, by a long shot, best to get a better quality one, have a look in the Maintenance section, lot's of info on this topic.
post #3 of 12 (permalink) Old 03-30-2015, 02:59 AM
Deano's Avatar
The one supplied with mine was shite. Put out over 17 volts. Find a decent one or better still ride it regularly. My battery is 3 1/2 years old and still o.k. Ride her 4-5 times a week for work and pleasure. Even makes going to work fun, least 'till I get there!
Deano
Deano is online now
post #4 of 12 (permalink) Old 03-30-2015, 03:44 AM
gotojoe's Avatar
Need a charger ? Get a Ctek..
joe
gotojoe is offline
post #5 of 12 (permalink) Old 04-01-2015, 03:10 AM
Miko's Avatar
joe
+1
I use the weakest Ctek "XS 0.8" on a daily basis for last 5 years (even in summer if I assume that I will not use the bike for more than a few days in a row).
Before Brutale I used it on the Aprilia V2 990 Rotax engine, which is known to require a good voltage for starting. No problems at all.
Btw, Ctek has a good range of accessories, although I personally use only THIS (as a power supply for navigation on longer trips or charging a cell phone).
Miko is online now
post #6 of 12 (permalink) Old 04-03-2015, 03:35 AM Thread Starter
KingKole02's Avatar
Thanks folks. I have two battery tenders for other vehicles. Was thinking of using the factory but if it's not good then go with what I have used and link. Thanks again.
Battery Tender brand cycles also. I have used for over a few years with my other vehicles.
post #7 of 12 (permalink) Old 04-06-2015, 03:37 AM
Formerly known as Lumiator
LO111's Avatar
Originally Posted by Miko View Post
...I use the weakest Ctek "XS 0.8" ...
Exact this one was provided with my 1090.
Btw, Ctek has a good range of accessories, ...
Yes, they have.
I fitted this "Comfort indicator Panel" to make it an easy job to plug in the charger whenever I leave the bike in the garage.
...just for one day.
LO111 is offline
post #8 of 12 (permalink) Old 04-10-2015, 10:04 PM
Wink ?
coming up on 1,500,000 miles on bikes......
never have used a charger.......
ride your bikes
post #9 of 12 (permalink) Old 04-11-2015, 01:25 PM
LO111's Avatar
ride your bikes
I admit culpability, your honor.
LO111 is offline
post #10 of 12 (permalink) Old 04-27-2015, 10:21 AM
Yes, they have.
Sir, may i ask how you accomplished this clean install of the charger plug in? I just purchased the same unit and was wondering if that carbon piece is a custom one off?
Thank you.
wildbill is offline
