No indicators on the right hand side... Fuse? - MVAgusta.net
post #1 of 9 (permalink) Old 02-18-2015, 09:15 AM Thread Starter
Tacklebury's Avatar
Hi guys,
Having nearly died twice yesterday I discovered that it wasn't wvery driver trying to get me but the fact every right hand turn I wasn't displaying indicators!!not ideal in the UK where we drive on the left so cross the oncoming traffic when turning right!!
I've not had a chance to check yet but wanted to ask if this is common and where the fuse box is?
I'll have a look after work but any heads up will be appreciated.
Tack
Tacklebury is offline
post #2 of 9 (permalink) Old 02-18-2015, 10:12 AM
The fuse box is behind the grey undertank panel on the right side of the bike. Pry the panel away from the bike from the back near the seat then slide it toward the back of the bike. DO NOT pry it away from the tank towards the front. You'll break it.
post #3 of 9 (permalink) Old 02-18-2015, 10:16 AM
mv raptor's Avatar
IT might not be the fuse box i have just had the same prob only one indicator working on l/h side was told to check the wireing on indicators first and i found a doggy conection on rear indicator l/h side its working now. 910R also check the bulbs.
mv raptor is offline
post #4 of 9 (permalink) Old 02-18-2015, 10:50 AM Thread Starter
Tacklebury's Avatar
Thanks for the replies
Will have a look in a few mins.
post #5 of 9 (permalink) Old 02-18-2015, 11:56 AM Thread Starter
Tacklebury's Avatar
So... Changed fuses and no joy.
Called garage and machanic suggested just following the wiring back and see when they work.
Sorted. However I don't think the main loom should smell of burning and crackle when moved!!! Argh!!!
As the main loom passes the right hand side of the heads it routes down slightly and meets more looms. That's where it appears to be shorting out.
Mv collecting it tomorrow morning.
Arse.
post #6 of 9 (permalink) Old 02-18-2015, 03:06 PM
CTD
CTD's Avatar
not good, good luck hope they sort it out quickly
CTD is offline
post #7 of 9 (permalink) Old 02-19-2015, 03:36 PM Thread Starter
Tacklebury's Avatar
Figured i'd update for the record.
Mv collected the bike this morning to take a look at the problem.
They discovered that the large bunch of wires which appears to have a short is the main loom as i thought. They explained that once the outer was removed they think the factory have doubled up the loom as it was a little too long!!
They couldn't see a wire that was broken but weren't overly happy with the loom so have ordered a new one from the factory.
Bike is back in my garage, i can see they have pulled through the extra wires that were doubled over and pulled them towards the front forks. i'd say maybe 2-3 inches max.
New parts should be in with 7-10 days then i assume it'll be a strip down to fit the new loom!
God bless warranties!
post #8 of 9 (permalink) Old 02-19-2015, 03:41 PM
number2's Avatar
better put the stock exhaust on so they don't tell you the warranty is void
number2 is online now
post #9 of 9 (permalink) Old 02-19-2015, 04:32 PM Thread Starter
Tacklebury's Avatar
The joys of buying it from them with it already fitted!!!!
