Is this normal for a steering damper?? - MVAgusta.net
 4Likes
  • 1 Post By dudman
  • 1 Post By pittmeister
  • 2 Post By dansoarr
post #1 of 7 (permalink) Old 10-15-2019, 03:30 PM Thread Starter
jaramharamharam's Avatar
My 2015 F3 800 came with a Moto corse damper mounting kit and an Öhlins damper. The whole thing seemed so flimsy to me, so I changed the bolts (ordered direct from Design Corse) assuming the main attaching bolt maybe was stripped or somehow bent, which made the damper so flimsy.
But it still did the same thing... Anyone also have this exact kit on your F3? Is it supposed to be this loose? If not, whats causing this? I can't quite figure it out...
Video below.
2015 F3 800
jaramharamharam is offline
post #2 of 7 (permalink) Old 10-15-2019, 03:53 PM
dudman's Avatar
Video below.
Looks to me the bolt head is too small or the hole has opened up.
What's the diameter of the hole? Will check mine tomorrow for a size.
John
theknurl likes this.
dudman is offline
post #3 of 7 (permalink) Old 10-15-2019, 03:54 PM
Normal as long as it's not touching your tank. Like a shift linkage there are there are some heim joints that give it that movement. Since the bars to do not rotate on the same plane the damper is bolted to, some movement is required to prevent binding.
esq'z me likes this.
2007 910R and 9 other bikes
pittmeister is offline
post #4 of 7 (permalink) Old 10-15-2019, 07:32 PM Thread Starter
John
Thanks @dudman. Top its 10mm and bottom its 6mm.
2015 F3 800
post #5 of 7 (permalink) Old 10-15-2019, 07:33 PM Thread Starter
Thanks pittmeister. Yeah I totally get the idea of why there needs to be play. It's not touching, it's just that the play is SO much. Never seen anyone's damper have THAT much play, thats all. Does yours have that much give?
2015 F3 800
post #6 of 7 (permalink) Old 10-16-2019, 05:29 AM
dansoarr's Avatar
With these arrangement's and another similar on a GSXR I had with a WP damper across the tank, is to add an oring under the lower rose (spherical) joint. The idea is to limit movement via vibration etc, but if the system needs the motion the oring will compress. it also removes the metal on metal noise.
I have no idea what oring I have fitted, I just open my box of nitrile orings and find something that fits.
esq'z me and jaramharamharam like this.
2015 MV F4, ABS
others
GSXR 1000
GSXR 750
dansoarr is offline
post #7 of 7 (permalink) Old 10-16-2019, 01:28 PM
dudman's Avatar
My top hole is 9mm and bolt just under
dudman is offline
