F3 800 rear sprocket - MVAgusta.net
 2Likes
  • 1 Post By esq'z me
post #1 of 9 (permalink) Old 08-07-2019, 09:10 PM Thread Starter
I bought new rear sprocket, carrier flange and what not. When I try to put it on, I can't quite get the carrier flange on. I get the sprocket carrier and the sprocket on. It seems to be off a bit. I thought if I removed the front sprocket and chain I'd be able to get it on. But I can't get the front sprocket off.
Leviswanger is offline
post #2 of 9 (permalink) Old 08-08-2019, 06:47 AM
Did you loosen the pinch bolts and rotate the hub to the loosest position??
Fastspy likes this.
post #3 of 9 (permalink) Old 08-08-2019, 09:23 AM Thread Starter
I did not. Also. I sprocket I got has 42 teeth and the OEM one has 41. So I bought a new one with 42 teeth. Should get here this weekend.
post #4 of 9 (permalink) Old 08-08-2019, 10:14 AM
what sprocket did you end up buying? I know when i went to a 520 sprocket it could go on 2 ways, one was clearly wrong once installed.
As mentioned above you should loosen the pinch bolts and loosen the hub to simplify things..be sure to use a torque wrench on the hub bolts.
jdgun is offline
post #5 of 9 (permalink) Old 08-08-2019, 11:00 AM
You have to loosen the chain (rotate the hub) to replace sprockets, and then re-adjust the chain.
jdgun likes this.
post #6 of 9 (permalink) Old 08-08-2019, 12:05 PM Thread Starter
I bought a superlight RS7
post #7 of 9 (permalink) Old 08-08-2019, 12:05 PM Thread Starter
I appreciate all the help, the both of you are always helpful and knowledgeable. I'll try that when I get home for work.
post #8 of 9 (permalink) Old 08-08-2019, 06:42 PM Thread Starter
What should I re torque it to?
post #9 of 9 (permalink) Old 08-08-2019, 08:32 PM
15lbft/20Nm..... The factory spec is too high and can distort the hub bearings. Ask Noel.
That's the pinch bolts....the wheel and sprocket nut are 220 Nm
