Ohlins steering damper bolt question - MVAgusta.net
 3Likes
  • 1 Post By Dutch MV
  • 1 Post By jaramharamharam
  • 1 Post By rodprice
post #1 of 8 (permalink) Old 07-04-2019, 10:19 PM Thread Starter
jaramharamharam's Avatar
Can anyone tell me the specs for these two bolts that belong to a Motocorse Ohlins steering damper kit for an F3 800? Thanks.
2015 F3 800
jaramharamharam is offline
post #2 of 8 (permalink) Old 07-05-2019, 06:13 AM
They will be metric standard. Measure the ID....
looks like 8 mm and 6 mm from the photo. 6x1.0 and 8x1.25 threads....
length depends on what is being fastened. Head type is up to you, but likely allen (internal hex) type.
post #3 of 8 (permalink) Old 07-05-2019, 09:28 AM
I can once I get home...
2015 MV Agusta F3 800
2012 Ducati Panigale 1199S
2011 Triumph 675R
jdgun is offline
The Following User Says Thank You to jdgun For This Useful Post:
post #4 of 8 (permalink) Old 07-09-2019, 12:31 AM
Dutch MV's Avatar
Indeed, M6 and M8 bolts ... Lengths you can simply measure but are not that critical as they won't bottom out so to speak.
I bought the bolts myself and choose for titanium versions.
For your info, I bought the ÷hlins used along with the brackets but it lacked the proper bolts so I simply measured it, ordered bolts and made it complete.
jaramharamharam likes this.
Sergio -- Initial succes or total failure ! --
Dutch MV is offline
post #5 of 8 (permalink) Old 08-03-2019, 09:13 AM
Dutch MV's Avatar
I need to add one important detail !
Make sure the M6 bolt that connects the damper clampmount to the top fork plate (see picture) is NOT too long !
So the thread where the finger is pointing at is where the the M6 bolt from the damperclamp enters.
If that is too long it will stick out to far (as it threads through the mount) and it will touch and scrape the bracket that holds one end of the Damper.
So when you steer this will be not as smooth as you'd like and it will have spots where resitance is a lot higher so steering will not be fluid at all.
When you use the proper length this will not happen as there simply isn't enough thread left when tightened and it will not stick out far enough.
Dutch MV is offline
post #6 of 8 (permalink) Old 08-15-2019, 08:04 PM Thread Starter
Thank you @Dutch MV! Actually in the end, the amazingly nice people at Design Corsa sold me the bolt kit from an existing kit, and they got MotoCrosa to ship them a new set (with a ridiculously long time delay!). So, the bolt they sent was the exact length I needed.
JerryJoose likes this.
2015 F3 800
post #7 of 8 (permalink) Old 08-16-2019, 07:26 PM
Dimensions are 6 x 15 & 8 x 25
rodprice is offline
post #8 of 8 (permalink) Old 09-11-2019, 06:14 AM
Bruce Taylor's Avatar
That does not surprise, top class company
Bruce Taylor is offline
