Rivale Start Problem - MVAgusta.net
 3Likes
post #1 of 18 (permalink) Old 04-04-2019, 01:07 AM Thread Starter
Bape47's Avatar
Hi guys
My rivale can start only the 1st start after the ride the bike wont start until battery death but everytime i use the batter jump the bike will start again
is it the problem with the battery? cause i got change my new battery 1 time and the bike cant start at the 1st either,put it back old battery bike can start again
Bape47 is offline
post #2 of 18 (permalink) Old 04-04-2019, 07:21 AM
So, you replaced the battery and the new battery will not start the bike?
The old battery will start the bike?
post #3 of 18 (permalink) Old 04-04-2019, 01:20 PM Thread Starter
Bape47's Avatar
Yes correct,new battery on i try to start it wont,i put my old battery it start but old battery can start only at 1st start every ride bike wont start again until u use battery jump then the bike start Jesus
Bape47 is offline
post #4 of 18 (permalink) Old 04-04-2019, 02:12 PM
What brand is the new battery?
post #5 of 18 (permalink) Old 04-04-2019, 07:12 PM Thread Starter
Bape47's Avatar
It was e cheap brand,i return it already
This one :
https://www.batteriesplus.com/batter...13/cylaz10sxta
Bape47 is offline
post #6 of 18 (permalink) Old 04-05-2019, 06:56 AM
How is your charging system????
post #7 of 18 (permalink) Old 04-05-2019, 09:45 AM
This one :
With batteries, you truly get what you pay for. Get a Yuasa YTZ 10S and be done with it.
post #8 of 18 (permalink) Old 04-05-2019, 06:41 PM Thread Starter
Bape47's Avatar
Idk how to check that
Bape47 is offline
post #9 of 18 (permalink) Old 04-05-2019, 07:02 PM
Connect a voltmeter to your charger connection (the one on the bike that you connect the battery tender to when you're not riding).
You will see the standing voltage of the battery. Should be 12.8~13.5 volts with a good fully charged battery.
Turn on the key and see how much the voltage drops (it shouldn't drop much at all).
Start the bike (note how low the voltage drops during cranking. Must stay above 10 volts).
Once running note the voltage. Should be around 14.5 volts. It should stay around there from idle to high rpm.
Turn on the high beam, the turn signals the brake light and blow the horn all at the same time.....should stay around 14.5 volts. Might drop a bit but should never drop below your standing battery voltage measured earlier.
silentservice703 likes this.
post #10 of 18 (permalink) Old 04-07-2019, 03:09 AM Thread Starter
Bape47's Avatar
Ok ill see thank you
Bape47 is offline
