Gas Position; Stop Engine. - Page 2 - MVAgusta.net
post #11 of 14 (permalink) Old 02-12-2019, 05:13 PM
Tony F's Avatar
Originally Posted by GREGOSTINI View Post
The throttle handle assembly has been updated since the early models to part # 8E00B5444 which incedentally has a noticably heavier return spring. I picked one up from a wrecker/dismantler over here, fitted it and had my local dealer clear the error code and install the latest map.
The springs are the same overall size, just differing wire gauges and number of turns, and can be swapped between the throttles if you prefer the softer spring.
Tony
Tony F is online now
post #12 of 14 (permalink) Old 02-21-2019, 08:17 AM
TruffleShuffle's Avatar
Hi Greg,
This might be a silly question, but how can you tell the throttle is the latest version? I'm looking at replacing mine from one on eBay, as I'm still regularly getting the Gas Position error, but I want to be sure I'm not getting an older, outdated throttle.
Cheers,
Nick
2015 MV Agusta Stradale
TruffleShuffle is offline
post #13 of 14 (permalink) Old 02-26-2019, 04:03 PM
GREGOSTINI's Avatar
Originally Posted by TruffleShuffle View Post
Hi Greg,
Cheers,
Nick
G'day Nick,
Unfortunately, you cannot tell them apart visually as far as I can see. You would need to trust the seller. Once the part is fitted, you can definitely feel that the return spring is heavier. And yes, you can switch back to the old spring if you prefer, as Tony said.
Regards, Greg.
GREGOSTINI is offline
post #14 of 14 (permalink) Old 03-02-2019, 02:06 PM
Thanks for the info. The bike is at the dealership next Friday so I'll ask them to take a look at the throttle and see if they can ascertain its age (I always assumed a 2015 bike would be on the latest anyway).
