New service bulletin for three cylinder models? - Page 11 - MVAgusta.net
 21Likes
post #101 of 102 (permalink) Old 04-30-2019, 08:40 PM
Update: Fixed!
I identified 2 issues which caused my problem. In the engine manual for the clutch section, page 12, I believe I got the ring with the tapered side inserted backward. It's on the diagram which shows the engine side. The other issue was in the picture I've attached. My hub was not seated properly. In this picture, it is seated correctly and you see the back part of it (golden color) fits through it nicely. Apparently I did not quite fit it correctly which was causing the hub to sit further out than it should, by a couple mm. I hope this is helpful to future readers that may come across similar problems.
esq'z me likes this.
2015 F3 800
Spark is offline
post #102 of 102 (permalink) Old 05-01-2019, 08:25 AM
Sometimes the devil is in the details...nice result. Hopefully it all works well when snugged back up!
