Valve / spring failure - DIY!!! - Page 3 - MVAgusta.net
 53Likes
post #21 of 90 (permalink) Old 09-08-2018, 08:09 AM
Originally Posted by airjawed View Post
Doing just the intake cam I believe can be done with engine in place and only a little extra work during a major servicing (valve cover removed) when I measure valve clearance.
What are your thoughts?
Replacing the cam with engine in place is the same as doing a valve adjustment. You take the cam out to swap shims...so yes, that will be relatively easy.
I think your theory on the springs and valve guides as likely causes for the original failures are spot on...not the cam lobe ramps.
Thanks for sharing all your information and photos.
airjawed likes this.
post #22 of 90 (permalink) Old 09-08-2018, 07:45 PM Thread Starter
airjawed's Avatar
My theory is the power and rideability part.
The information regarding what is central to failure comes from the trusted source doing the work. I would agree that a lobe with less lift would be less stressful to the springs. The information I've received is that the cam profile, spring and guides can all be improved (and were) in the newest F3 800. His advice was to get the revised cam as that would greatly improve the reliability in my street application as that worked in the race world as well.
I wish I had the budget to do all the things I wanted in the bike world. I'd make this a track oriented bike and have a lot of fun making it with top spec hardware but I have reality to deal with. So, in the meantime I appreciate that this thread might be helpful or at the least interesting!!
cherche likes this.
2014 MV Agusta F3 800 ABS
airjawed is offline
The Following User Says Thank You to airjawed For This Useful Post:
post #23 of 90 (permalink) Old 09-09-2018, 03:49 AM
Moriwaki's Avatar
Thanks a lot for sharing this story!
Glad to see there are options for repair when it drops a valve...
2013 F3 800 (track only)
The older you get, the faster you was
Moriwaki is offline
post #24 of 90 (permalink) Old 09-09-2018, 07:59 AM
Mario21's Avatar
I have same issue with B3 675 MY2013. In my case air box looks like a part of grinding machine. One intake valve completely damaged second as well, piston drop down and piston rod went outside from crank case. Good I’m still alive as it happen at speed 190km/h. I heard that there is some company in Italy which makes heads for racing and fixing valve issue at F3 engines. But after 2 days of net searching nothing found yet.
Mario21 is offline
post #25 of 90 (permalink) Old 09-09-2018, 08:20 AM
@Mario21: You can use the EDIT button at the bottom of your post to go back and change information found to be erroneous.
post #26 of 90 (permalink) Old 09-09-2018, 07:55 PM
So won’t changing the cam require a re map of the ECU? Or will th you bike be smart enough to notice and adjust for it?
Strider78rr is offline
post #27 of 90 (permalink) Old 09-09-2018, 09:56 PM Thread Starter
airjawed's Avatar
The information that I have is that remap is not mandatory. But I do believe that a remap/dyno tune would optimize the fueling. It is likely similar to installing a slip-on exhaust. Most bikes don't require a remap for that little of a change but if you have the resources to do it then it should be done.
My bike actually kept running with a dropped valve. It didn't even trigger a code on my dash! I'm sure deeper analysis of the fueling and trims would show a problem but it was not enough to trigger a warning of any sort.
I could always try a map from a newer model if it did indeed present a fueling issue.
airjawed is offline
post #28 of 90 (permalink) Old 09-09-2018, 10:02 PM
I still haven't gotten my F3 yet but all this dropped valve talk has me shaking in my boots....
post #29 of 90 (permalink) Old 09-10-2018, 05:37 AM
The dropped valves were mostly a first edition problem with the 675 cc bikes. And 100% of the bikes were not affected. A fair number, but not every one.
What year and model are you getting? Regardless, I would not let this concern deter you or keep you awake at nights.
Strider78rr likes this.
post #30 of 90 (permalink) Old 09-10-2018, 07:51 AM
‘14 f3 800.
