3 Cylinder Head differences? - MVAgusta.net
 7Likes
  • 3 Post By airjawed
  • 1 Post By airjawed
post #1 of 10 (permalink) Old 08-12-2018, 03:49 PM Thread Starter
airjawed's Avatar
I most likely have a valve failure and looking to perform my own repairs. I have yet to open the bike up and discover the extent of failure but I may have been lucky as far as cylinder head failures can be. Failure happened basically at idle with very little rpm used afterwards. Engine didn't even stall.
My question is if all the 3 cylinder heads were similar in terms of the block of metal. I know the cam/spring/valves are different but I can source used 3 cylinder heads from bikes other than F3 800's. Its August in Italy and I would like to make my track day in Oct!
On a positive note: I got 25,000 miles on the bike. Never a garage queen! Looking forward to having it back to what it was!!
2014 MV Agusta F3 800 ABS
airjawed is offline
post #2 of 10 (permalink) Old 08-15-2018, 03:40 PM
Im at 23k and believe I also may have this same issue.
What are your symptoms?
Atom is offline
post #3 of 10 (permalink) Old 08-15-2018, 11:30 PM Thread Starter
airjawed's Avatar
PM sent
I have opened up the intake air box and am able to see that I have a failed intake valve at cylinder 2. Tried to get a good picture with camera but the girlfriend pulls up at the time complaining of the heat. Also tried to get my old micro usb endoscope working but it won't with my new phone. I'll have pics soon enough.
airjawed is offline
post #4 of 10 (permalink) Old 08-17-2018, 09:32 PM
Angelo-MV's Avatar
Didn't you check the valve clearance not too long ago? If so I guess it doesn't matter if they are in spec or not for them to fail...
Angelo-MV is offline
post #5 of 10 (permalink) Old 08-18-2018, 07:27 AM Thread Starter
airjawed's Avatar
I did and they were in spec at 24,000 miles. Most likely the spring failed leading to valve to cylinder disagreement! I'll be opening up the head this weekend and have more information when that is done. All the other intake valves including on the same cylinder are actually still good... they all hold fluid when sprayed into the throttle body(throttle body cleaner).
airjawed is offline
post #6 of 10 (permalink) Old 08-19-2018, 05:20 AM
PTsalas's Avatar
Keep us in the loop with regards to what parts you get (OEM etc) for your re-build.
Looks like valve springs and thereafter the guides are the items causing the failures. I think MV have the dual spring setup on the new 800s and a revised single spring setup on the 675. Both have revised valve guides.
In my case, do you think it will be worth the effort to take off the head and replace the springs and guides with updated parts? It is the guides that I worry about the most as an engineering shop would have to do that and trust is a major issue of mine. Another option is ride it to failure then replace...
PTsalas is offline
post #7 of 10 (permalink) Old 08-19-2018, 11:08 AM Thread Starter
airjawed's Avatar
I've got a great resource who was part of MV usa. I'll be pulling the head of today or so and sending pics and sending to him for the repair. APE is also a great machine shop that can rebuild heads in the US.
My attitude is fix it as you go. This stuff is meant to be used and enjoyed. In my case I do my own labor for the most part. If I had to have a shop do this stuff all the time I'd be broke and likely not even be in this hobby.
Sometimes I like to think of all the parts going down the highway that can fail. All those cars and all those valves just waiting to fail! Just kidding. Don't think of all the negatives. Enjoy life and move forward!!
airjawed is offline
post #8 of 10 (permalink) Old 08-19-2018, 06:26 PM Thread Starter
airjawed's Avatar
1.5 hours yesterday and 2.5 hours today gets me this!!
Black_Gold_Saw, jdgun and Mutsuaki like this.
airjawed is offline
post #9 of 10 (permalink) Old 08-22-2018, 02:12 PM Thread Starter
airjawed's Avatar
So I was able to remove head and reveal the issue. As suspected by my contact the valve spring broke leading to associated damages. Will be replacing head and piston for cylinder 2 and possibly connecting rod.
Black_Gold_Saw likes this.
airjawed is offline
post #10 of 10 (permalink) Old 08-30-2018, 07:29 AM Thread Starter
airjawed's Avatar
More pics
nk140, Black_Gold_Saw and gotfolk like this.
airjawed is offline
You may post new threads
You may post replies
