Running on - MVAgusta.net
  • 1 Post By lmmperalt
post #1 of 5 (permalink) Old 07-04-2018, 12:59 PM Thread Starter
UkNick's Avatar
Running on
Hi guys, after approx 30 miles on a run when i close the throttle to change down say coming to a junction the revs dont drop to tickover but hover around 1.5 - 2.5 bumble up and down for a bit then drop to idle, any ideas thanks.
UkNick is offline
post #2 of 5 (permalink) Old 07-04-2018, 04:30 PM
Hi Nick.
I had similar issues with my second dragster. Tested for potential air leak first, rebalanced throttle bodies and it still persisted. Is this something that is just started happening or is it something that's always happened?
Some further questions: how many km have you put on the bike, are you the first owner, any mods?
I ended up resolving my issues by changing the ecu map/firmware to an older one, as the engine braking in lower gears is reduced on newer firmware (I'm assuming to make down shifting more comfortable and pass emissions testing by slowing throttle closing). Most noticeable in 3-->2 and lower.
To fully solve it, I purchased ECU Studio and reconfigured the engine braking per gear and for different rev combinations (ECU Studio is brilliant by the way - thanks Luca!).
Hope that helps.
Nick M
Nicklemouse is offline
The Following User Says Thank You to Nicklemouse For This Useful Post:
post #3 of 5 (permalink) Old 07-05-2018, 01:47 AM
cherche's Avatar
Had the same on my 2018 Brutale RR.
It occurred only in high Altitude here in the Italian Alps.
It never happened lower than let's say 1500 m.
2018 Brutale 800RR
cherche is online now
The Following User Says Thank You to cherche For This Useful Post:
post #4 of 5 (permalink) Old 07-05-2018, 11:05 AM Thread Starter
UkNick's Avatar
Hi Nick, it only happens occasionally a quick blip of the throttle settles it down..
UkNick is offline
post #5 of 5 (permalink) Old 07-05-2018, 11:18 AM
lmmperalt's Avatar
Sometimes that happens with my F4 1078RR. But 90% of the time is good. I talked with 2 different garage guys, I had the map (power commander V) checked and the bike tested on the dyno. In my opinion it is not normal but it is not a problem.....now. I am thinking of installing the autotune. Maybe after autotune detects and corrects this issue (after loading the maps of autotune in the actual map) this will be over. But honestly, that is something that right now does not botter me.
UkNick likes this.
Best Regards,
Luis Miguel
lmmperalt is offline
The Following User Says Thank You to lmmperalt For This Useful Post:
