Radiator Fan F3 - MVAgusta.net
post #1 of 51 (permalink) Old 04-11-2018, 12:08 AM Thread Starter
Radiator Fan F3
When is the fan suppose to turn on?
I think mine doesn't work.
I ran my bike in neutral on a stand until it was 1 bar over the middle line and the fan didn't turn on.
Neal is offline
post #2 of 51 (permalink) Old 04-11-2018, 12:58 AM
Pulse's Avatar
At the mid line. Mine usually turns on at the line, but sometimes 1 bar above the line. Probably after 2-3 minutes at that level, at the most
Pulse is offline
post #3 of 51 (permalink) Old 04-11-2018, 04:20 AM
Wildfire's Avatar
Mine is usually on a little while after 1 bar over the mid line.
Wildfire is offline
post #4 of 51 (permalink) Old 04-11-2018, 08:52 AM
Probably comes on at around 210 F degrees and cuts off at around 190 F....... the bar gauge can be variable on any given bike. Let it sit there and idle until you get to 2 bars above center...I'll wager it comes on.
post #5 of 51 (permalink) Old 04-14-2018, 12:28 AM Thread Starter
I got it to 2 bars over the middle, the Fan didn't turn on.
I turned of the motor and let the bike sit and it went up to 2 more bars sitting there with the motor off, which was all the way to max.
How does the bike go up 2 more bars when it isn't even running at all?!?!
Neal is offline
post #6 of 51 (permalink) Old 04-14-2018, 09:02 AM
Most likely due to the location of the temperature sensor. It is high in the system and heat rises. When forced circulation is lost (engine off) the heat just rises to the sensor.
post #7 of 51 (permalink) Old 04-14-2018, 05:13 PM
airjawed's Avatar
Did the fan kick in when it was 4 bars over middle? If not then you definitely have an issue with the fan.
airjawed is offline
post #8 of 51 (permalink) Old 04-14-2018, 11:17 PM Thread Starter
Yah, I am looking for a fan on ebay. Anyone know if a B3 or Draggster fan is compatible with a F3?
Neal is offline
post #9 of 51 (permalink) Old 04-14-2018, 11:44 PM
Pulse's Avatar
Are you sure its the fan? Have ypu tried testing it directly? A fuse or busted sensor might be a more likely cause.
The B3 fan should fit - check if its the same part number
Pulse is offline
post #10 of 51 (permalink) Old 04-15-2018, 03:53 AM Thread Starter
Well, I replaced the water sensor in the radiator and I checked the fuse box on the side of the bike- if there is anything else to check than that I don't know about it.
Well, it looks like the dragster fan should work, the labels on the picture were the same as the f3.
Neal is offline
