Exhaust Valve servo error fix - Page 2 - MVAgusta.net
post #11 of 23 (permalink) Old 04-01-2019, 02:40 PM
Help us help you...what year and model is your bike?
post #12 of 23 (permalink) Old 04-04-2019, 01:49 AM
Blinxnot's Avatar
Thanks for this info. I had the exhaust valve servo error over past month. Used this technique and fixed my F3.
airjawed likes this.
Blinxnot is offline
post #13 of 23 (permalink) Old 04-05-2019, 12:48 PM
Bad Role Model's Avatar
Originally Posted by airjawed View Post
Is the side stand plug reconnected? The switch is part of the side stand and may be outside of the stops. A simple investigation should reveal the problem.
I never disconnected the connection. But after reading your suggestions I disconnected it, cleaned it and out a dab of electrical grease in and reconnected. I’m not sure what you mean by stops. I guess I should’ve taken pictures and posted to show what I did. For now I unscrewed the sensor from the side stand and took the sensor off. I then took off the side stand and cleaned everything. I put everything back together and the side stand works as before. I disconnected the sensor for now and after a few rides the exhaust valve malfunction came back. Very frustrating.
2013 MV Agusta F3 675 EAS
Bad Role Model is offline
post #14 of 23 (permalink) Old 04-05-2019, 12:50 PM
I’ve received this reply from you before. I am using my iPhone and went into settings. There is no options for what bike I have. I exited enhanced mobile view and then went to desk top version to find a bio section I filled out with my bike info. If that still is showing clearly my bike is a 2013 MV Agusta F3 675 EAS.
post #15 of 23 (permalink) Old 04-05-2019, 12:51 PM
What do you mean by used this technique? As in you followed directions step by step? No other issues? Has it been running fine ever since?
post #16 of 23 (permalink) Old 04-05-2019, 02:34 PM
Originally Posted by Bad Role Model View Post
Ive received this reply from you before. I am using my iPhone and went into settings. There is no options for what bike I have. I exited enhanced mobile view and then went to desk top version to find a bio section I filled out with my bike info. If that still is showing clearly my bike is a 2013 MV Agusta F3 675 EAS.
Now your bike shows clearly in the signature line...thanks.
post #17 of 23 (permalink) Old 04-05-2019, 05:11 PM Thread Starter
airjawed's Avatar
Healtech sells an exhaust servo eliminator. Just remove the servo and mechanical cables. Plug in the exhaust servo eliminator.
Healtech part ESE-A01
2014 MV Agusta F3 800 ABS
airjawed is offline
post #18 of 23 (permalink) Old 04-06-2019, 07:28 AM
Just a word of caution about this: The servo eliminator does not always work. Healtech is aware of this. It appears to be hit-or-miss and there are several threads about it.
post #19 of 23 (permalink) Old 04-06-2019, 10:30 AM Thread Starter
airjawed's Avatar
True, from what I understand the newer MV's will not work with it. But, it does work for 2014 and presumably with a 2013.
airjawed is offline
post #20 of 23 (permalink) Old 04-13-2019, 05:52 PM
Just installed the healtech emulator on my 2018 Dragster SC. Pulled the motor and wires. On way to mechanic had 3 errors thrown in 25 miles. On ride home, cel cleared, and bike ran like a champ. A little louder at the bottom, but who cares.
But, maybe Im just lucky.
Sent from my iPad using Tapatalk
Mschwechter is offline
