Gear change sensor - MVAgusta.net
 4Likes
post #1 of 32 (permalink) Old 01-05-2018, 02:26 PM Thread Starter
Gear change sensor
Changing the sensor and the new doesnt fit. What am I missing. The instructions say that the spring loaded pin should be removed but it is stucked.
racermasen is offline
post #2 of 32 (permalink) Old 01-07-2018, 02:51 AM Thread Starter
Problem solved
post #3 of 32 (permalink) Old 01-07-2018, 03:19 AM
Originally Posted by racermasen View Post
Problem solved
How?
post #4 of 32 (permalink) Old 01-07-2018, 03:29 AM Thread Starter
How?
The pin and spring are loose but it's hard to grab it. It took a while but succeeded after a while (and after a few beers )
post #5 of 32 (permalink) Old 01-07-2018, 04:46 AM
Excellent!
post #6 of 32 (permalink) Old 01-08-2018, 04:44 AM
Out of interest: The kit comes with a new cable, where did you hook that up to ? To the charge connector or to the tilt sensor?
XJ750SECA --> RD350LC YPVS --> CBX1000F --> CBX550F2 --> RD350RR --> RD500YPVS --> FZ400R --> F3675 --> 899PANIGALE --> 959Panigale
RCEE is offline
post #7 of 32 (permalink) Old 01-08-2018, 05:01 AM Thread Starter
The cable is connected to the diagnostic connector.
File Type: pdf 9746_Service Bulletin n° 116 - Gear sensor B3 - F3_ENG.pdf (141.8 KB, 86 views)
post #8 of 32 (permalink) Old 01-08-2018, 05:06 AM
Ok, if you still experience problems with your gear indicator after that service bulletin please note there is another cable available!
Partnumber: 8000C0856 cablaggio adattatore marcia.
https://www.ricambi-mv.it/mvagusta-m...ione/8000C0856
The cable that comes with the original kit has a build in 12v to 5v converter. The cable i mention does not have a 12v 5v converter but grabs the 5v from the tilt sensor directly.
I had the kit installed too, and it worked good at first sight....but once the bike heats up the gear indicator still got loco. The 8000C0856 cable solves that.
Strange thing is, you won't find the cable in most oem suppliers like startwin. But it's available in some shops [google it]
I got mine from Home
Does it solve the issue for you ?
RCEE is offline
post #9 of 32 (permalink) Old 01-09-2018, 12:31 AM Thread Starter
[I'll post the Partnumber later]
My motorcycle is in pieces so i don't know. Some service before the race season begins.
But please give me the part number in case of it doesn't work.
Edward, Edward, RCEE and 1 others like this.
post #10 of 32 (permalink) Old 01-09-2018, 03:46 AM
@racermasen added info: http://www.mvagusta.net/forum/129-ma...ml#post2409858
RCEE is offline
