Odometer and speedometer stop to works - MVAgusta.net
post #1 of 8 (permalink) Old 06-23-2017, 04:09 AM Thread Starter
Hello,
i don't know what happened but after putting the petrol in my motorbike (MV Agusta Brutale 2014 800cc) i switch on the motorbike and staring i note the odometer and speedometer doesn't work anymore , then i restart again but not luck ... truly it is so strange i could not understand what happened ... next days i should bring the moto to the mechanic to check out the throttle anyway does someone met this issue that odometer and speedometer stop to works?
Jay
Jayjaycooper is offline
post #2 of 8 (permalink) Old 06-23-2017, 07:03 AM
I would check fuse number 5. I don't believe the bike should start if this fuse were blown though.
It might be as simple as disconnecting and reconnecting your Instrument Panel multi-pin connector to clean the contacts.
post #3 of 8 (permalink) Old 06-24-2017, 08:01 AM Thread Starter
Dear SilentService thanks again for your nice support... I just went to take the motorbike from the mechanic and following your advice I can fix the trouble.
I appreciate that.
post #4 of 8 (permalink) Old 06-24-2017, 08:02 AM
Let us know how you get along...
post #5 of 8 (permalink) Old 06-29-2017, 08:13 AM Thread Starter
dear Silenservice when I went to the mechanic I just told to disconnecting and reconnecting the Instrument Panel multi-pin connector to clean the contacts and clean with silicone dielectric grease plus he done a revision with software...
post #6 of 8 (permalink) Old 06-29-2017, 09:15 PM
GREGOSTINI's Avatar
How did you go with the gas position error, has it also been eliminated?
GREGOSTINI is offline
post #7 of 8 (permalink) Old 07-03-2017, 04:21 AM Thread Starter
Dear Gregostini ,
following your advise (to buy small tube of dielectric grease and apply it (or have a mechanic apply it) to every electrical connector plug ,particularly, for this problem, on the throttle assembly connector AND the two plugs that go into the ecu), in fact 2 weeks ago i apply this process and after 150 km i did not get the error "stop eng - gas position" ... the mechanic find out also a bit water in the fuel tank and luckily he got the MV Agusta software then makes a upgrade on the motorbike ....i can see the motorbike run smoothly without any particular error now.
i would update again this topic within few weeks if it will be helpful for who met the same my trouble
I should thank you a lot for your great tip !!!!
post #8 of 8 (permalink) Old 07-04-2017, 07:47 AM
Good to hear things have worked out!
