'15 Dragster 800 Cold Start - MVAgusta.net
post #1 of 23 (permalink) Old 05-22-2016, 12:49 PM Thread Starter
Been having trouble starting it up the first time when the weather is cold. It starts up, turns over, and then it dies after 3 seconds. It usually takes 4-5 tries until it finally starts up. I have already brought it in to a shop to re-sync the throttle bodies. What would be the solution to this? I've read so far in this forum that the possible solutions may be that it needs a new battery, sprag clutch, or it needs an updated map.
Thanks in advance.
Jeremy
jayescee is offline
post #2 of 23 (permalink) Old 05-22-2016, 06:46 PM
Sounds like sprag clutch.
Atom
Brutale Dragster RR
Atom is offline
The Following User Says Thank You to Atom For This Useful Post:
post #3 of 23 (permalink) Old 05-22-2016, 08:41 PM
TheX's Avatar
If the spins over properly your battery is fine, but the sprag is probably not OK.
Do something today that your future self will thank you for.
TheX is offline
post #4 of 23 (permalink) Old 05-23-2016, 01:25 AM Thread Starter
Well, riding it after work today, the bike stalled on me a couple times on the way home as I came to a stop. Seems like re-syncing the throttle bodies did not fix that problem of the Dragster... hooray?
jayescee is offline
post #5 of 23 (permalink) Old 05-23-2016, 03:44 AM
If it starts up then dies after 3 seconds, it cant be the sprag. It did its job by starting the engine.
Im not sure what it could be, but wanted to comment to discount the sprag
Kag
Kageira is offline
post #6 of 23 (permalink) Old 05-23-2016, 05:54 AM
Did it stall before you had the throttles synched?
Jono is offline
post #7 of 23 (permalink) Old 05-23-2016, 09:14 AM Thread Starter
Yes it stalled before I got the throttle sync'd
jayescee is offline
post #8 of 23 (permalink) Old 05-23-2016, 10:14 AM
Do the B3 bikes have the Cold Start Throttle lever?
post #9 of 23 (permalink) Old 05-23-2016, 10:58 AM
No - its all ecu/sensors.
Jeremy what did the shop say about your throttles? Were they miles off/OK/thereabouts? Was it an MV dealer?
Also what country are you in?
Jono is offline
post #10 of 23 (permalink) Old 05-23-2016, 12:34 PM Thread Starter
One of the air screws was turned all the way in. They adjusted and resync'd all of them. This was a shop that specialized in MV Agusta, Ducati, and etc. I'm in California, USA.
jayescee is offline
