2016 Dragster RR-Throttle response issues. - MVAgusta.net
post #1 of 18 (permalink) Old 05-21-2016, 10:31 PM Thread Starter
Maser's Avatar
My wife just picked up a 2016 Dragster RR on Friday and she seems to be having issues with the bike's throttle response; with less than 50 kms on the clock, twice now she gives it gas and nothing happens for 1 second or so and then full power kicks in. Is this a known mapping issue with the RR? She has it in sports mode. She never experienced this issue with the 2014 Brutale 800.
Toronto, Canada
Maser is offline
post #2 of 18 (permalink) Old 05-21-2016, 11:53 PM
To rule out traction control interference, turn traction control off and see if response improves - FYI if TC is on a high setting, it can activate when cornering and accelerating.
Nicklemouse is offline
The Following User Says Thank You to Nicklemouse For This Useful Post:
post #3 of 18 (permalink) Old 05-22-2016, 04:21 AM
Matt M.'s Avatar
Could be the throttle bodies are out of sync, or something of the like. Your dealer should be able to tune that out without a problem.
Matt M. is offline
post #4 of 18 (permalink) Old 05-22-2016, 06:24 AM Thread Starter
Maser's Avatar
I will try the TC today. Thanks
Toronto, Canada
Maser is offline
post #5 of 18 (permalink) Old 05-23-2016, 05:59 AM
All this ought to be sorted by now - esp on the RRs which were hailed as a great leap forward. Have you tried it in rain or normal to compare?
Jono is offline
post #6 of 18 (permalink) Old 05-23-2016, 07:27 AM Thread Starter
Maser's Avatar
It does it in every mode...
Toronto, Canada
Maser is offline
post #7 of 18 (permalink) Old 05-23-2016, 07:19 PM
bbrally's Avatar
Try changing the traction control to a low number. The problem will likely dissappear like it did with mine.
1969 T350
1983 RZ350
2001 RC51, gone but not forgotten
2014 CB650F, for sale...
2015 Brutale 800 RR
bbrally is offline
post #8 of 18 (permalink) Old 05-24-2016, 02:21 AM
GeorgeO's Avatar
Does this happen when upright or turning at a lean angle?
If lean angle - with TC set at 1 - you will have this problem.
GeorgeO is offline
post #9 of 18 (permalink) Old 05-24-2016, 06:13 AM Thread Starter
Maser's Avatar
She hasn't reporting the problem while leaning, only when accelerating in a straight line. I set the TC to 8 because of the new tires and breaking in period. Next time we are out, I will change it to 5 and see how it goes.
Toronto, Canada
Maser is offline
post #10 of 18 (permalink) Old 05-24-2016, 10:01 AM
Lean should not interfere with TC since there is no lean sensor.
Lacsap is offline
