Stalling[Quickfix......sort of] - MVAgusta.net
View Poll Results: Does your F3 suffer stalling issues?
Yes 3 75.00%
No, never had stalling issues 0 0%
Dealer still has not solved it 0 0%
Solved by dealer 0 0%
Dealer is unable to fix. 0 0%
Solved by the "quickfix'' 1 25.00%
Voters: 4. You may not vote on this poll
post #1 of 2 (permalink) Old 05-06-2016, 03:03 AM Thread Starter
Owning a 2012 F3 witch suffering the stalling issue i found out some kind of quick fix that seems to adress this issue very well.
Dealers seem to having some problems to adress this issue.
Browsing this forum and collecting all info the root cause of this issue might be an improper throttle body synchronization, especially the cil1[when sitting on the bike the most LEFT cilinder that is] air bleed screw found completly closed in most cases. So was mine.
When you find your Cil1 Air bleed screw closed, open it 1/2 [half] turn counterclockwise!
With a little patiance and a proper tool you can check this by removing the left fairing panel only:
Be aware that this is not a official fix, but a quick solution to avoid the removal of tank, airbox etc. To achieve a full professional result a throttle body sync might be the best solution. But for those without the proper tools for this This might be a solution to fix the most anoying bug on this bike in about 1 hour! Performed this fix on my own bike witch never stalled again since!
RCEE is offline
post #2 of 2 (permalink) Old 05-06-2016, 07:35 AM
Yep. That'll get you pretty close.
Jono is offline
